Basic Object Movements
After adding an object to Unigine, you can control its transformations with your control devices. This article shows how to control basic object movements and combine different transformations.
- An article on Matrix Transformations.
- An article on mat4 and dmat4 Unigine data types.
Direction Vector#
A direction vector is an important concept of mesh transformation. To move the node forward, you should know where is the forward direction of the mesh. When the mesh is exported from a 3D editor, it saves the information about the forward direction. And when you add the mesh to the Unigine, it will have the same orientation as it had in a 3D editor.
A mesh in Maya
The same mesh in Unigine
On pictures given above, the direction vector has positive Y-direction. To move this mesh forward, you should get the direction of the mesh by using the Y component (the second column) of the world transformation matrix of the mesh.
The point is that content creators and programmers should make an arrangement about the direction vector.
Basic Movements#
Moving Forward#
This section contains different ways of setting the forward movement of the mesh.
In this example, we used the "p" key pressing to move the mesh forward. The direction vector is visualized for clarity.
// AppWorldLogic.h
#include <UnigineLogic.h>
#include <UnigineStreams.h>
#include <UnigineObjects.h>
AppWorldLogic();
virtual ~AppWorldLogic();
virtual int init();
virtual int update();
virtual int render();
virtual int flush();
virtual int shutdown();
virtual int destroy();
// define the ObjectMeshStatic instance
// so that it will be deleted with the AppWorldLogic instance
Unigine::ObjectMeshStaticPtr mesh;
// AppWorldLogic.cpp
#include "AppWorldLogic.h"
#include <UnigineControls.h>
#include <UnigineEditor.h>
#include <UniginePlayers.h>
#include <UnigineMathLib.h>
#include <UnigineGame.h>
#include <UnigineMesh.h>
// define the movement speed
float movement_speed = 5.0f;
int AppWorldLogic::init() {
// enable visualizer
Visualizer::get()->setEnabled(1);
// create a camera and add it to the world
player->release();
// set the camera position and direction so that it is pointed at the object
player->setPosition(Vec3(4.0f, -3.401f, 1.5f));
player->setDirection(vec3(0.0f, 1.0f, -0.4f),player->getUp());
mesh_0->addBoxSurface("box_surface", vec3(1.0f));
// create the ObjectMeshStatic by using the new mesh
mesh = ObjectMeshStatic::create(mesh_0);
mesh->release();
// set the mesh position and material
mesh->setPosition(Vec3(4.0f,0.0f,1.0f));
mesh->setMaterial("mesh_base", "*");
// add the mesh to the editor
Editor::get()->addNode((mesh->getNode()));
// check if the key is pressed and update the state of the specified control
// you can use both 'p' or ASCII code (112)
ControlsApp::get()->setStateKey(Controls::STATE_AUX_0, 'p');
// start of the main loop
int AppWorldLogic::update() {
// get the frame duration
Mat4 transform = mesh->getWorldTransform();
Vec3 direction = transform.getColumn3(1);
// render the direction vector for visual clarity
Visualizer::get()->renderDirection(mesh->getWorldPosition(), vec3(direction), vec4(1.0f, 0.0f, 0.0f, 1.0f), 0.1f, 0);
// check if the control key is pressed
if (ControlsApp::get()->getState(Controls::STATE_AUX_0)) {
// calculate the delta of movement
Vec3 delta_movement = direction * movement_speed * ifps;
// set a new position to the mesh
mesh->setWorldPosition(mesh->getWorldPosition() + delta_movement);
Another Way of Setting Mesh Position#
The new position can be also set by using the setWorldTransform() function. The following examples contain the code from the update() function of the AppWorldLogic class. The part of controls initialization is the same for this method, the difference is in the update() function only.
mesh->setWorldTransform(translate(delta_movement) * transform);
Or you can change the translation column of the world transformation matrix (see the Matrix Transformations article) to move the mesh:
// check if the control key is pressed.
// here, you can also use transform.setColumn3(3, transform.getColumn3(3) + delta_movement);
transform.setColumn(3, transform.getColumn(3) + Vec4(delta_movement, 1.0f));
// set a new world transform matrix to the mesh
mesh->setWorldTransform(transform);
Rotation#
This section contains implementation of the mesh rotation.
You can rotate the mesh in two ways, by changing the transformation matrix via the setWorldTransform() function or via the setWorldRotation() function. The following example uses the second one:
// AppWorldLogic.h
AppWorldLogic();
virtual int init();
// define the ObjectMeshStatic instane
// define the rotation speed
float rotation_speed = 30.0f;
player->release();
mesh->release();
// you can use both 'o' or ASCII code (111)
ControlsApp::get()->setStateKey(Controls::STATE_AUX_1, 'o');
if (ControlsApp::get()->getState(Controls::STATE_AUX_1)) {
// set the node rotation along the Z axis
mesh->setWorldRotation(mesh->getWorldRotation() * quat(rotateZ(rotation_speed * ifps)));
In the example above, the node is rotated to the left by pressing the "o" keyboard key.
To rotate the object by using the setWorldTransform() function, you should replace the setWorldRotation() function with the following line:
mesh->setWorldTransform(mesh->getWorldTransform() * Mat4(rotateZ(rotation_speed * ifps)));
Combining Movements#
Combining different movement controls is not more difficult than adding only one movement control.
The following example adds a mesh to the world and allows you to control it. You can rotate the mesh by using the "o", "[" keyboard keys and move forward by using the "p" key.
// AppWorldLogic.h
AppWorldLogic();
virtual int init();
// define the ObjectMeshStatic mesh
// define the movement and rotation speed
float rotation_speed_left = 30.0f;
float rotation_speed_right = -30.0f;
player->release();
mesh->release();
// you can use both 'p', 'o', '[' or ASCII codes (112, 111, 113)
ControlsApp::get()->setStateKey(Controls::STATE_AUX_2, '[');
// get the current world transform matrix of the mesh
// check if the control key for movement is pressed
// check if the control key for left rotation is pressed
// set the node left rotation along the Z axis
mesh->setWorldRotation(mesh->getWorldRotation() * quat(rotateZ(rotation_speed_left * ifps)));
// check if the control key for right rotation is pressed
if (ControlsApp::get()->getState(Controls::STATE_AUX_2)) {
// set the node right rotation along the Z axis
mesh->setWorldRotation(mesh->getWorldRotation() * quat(rotateZ(rotation_speed_right * ifps)));
