decal_terrain_hole_base
A decal_terrain_hole_base material creates holes in Global Terrain using decals.
Prior Knowledge
  • Samples located in decals folder.
States
States
Materials editor, States tab.
Options
Jitter Transparency
Jitter transparency enables creating deferred transparency by using jittering. When enabled, a dither pattern is used for transparency imitation.
Jitter Transparency disabled
Jitter Transparency enabled
Only Touched Lods
Only touched Lods indicates whether the decal cuts out the surface of all terrain LODs or of only those ones with which it intersects.
UV Mapping
Base
Base option specifies which UV coordinates of the mesh will be used for base texture.
  • UV - map the texture using the UV coordinates of the mesh.
  • World - map the texture using world transformation (the texture is always projected atop).
Base Textures
Mask
Mask texture defines areas of holes in a TerrainGlobal object. Only R channel is used:
  • White pixels indicate that the area of a TerrainGlobal object will be transparent.
  • Black pixels indicate that the area of a TerrainGlobal object will be visible.
Mask texture applied
Mask texture
Parameters
All of the parameters have set default values, which can be replaced by your own ones.
Base Parameters
UV Transform
Base texture coordinates transformation.
Transparent Multiplier
Transparent multiplier is a multiplier of mask's colors. The higher the value, the darker pixels of mask are holes.
For this mask texture, results of Transparent multiplier usage with Jitter Transparency disabled are the following:
Transparent multiplier = 0.5; Transparent pow = 1.0
Transparent multiplier = 1.0; Transparent pow = 1.0
Transparent multiplier = 1.5; Transparent pow = 1.0
Jitter Transparency enabled:
Transparent Pow
Transparent pow is a power of mask's colors. The higher the value, the less contrast the mask.
Transparent pow = 0.01; Transparent multiplier = 1.0
Transparent pow = 1.0; Transparent multiplier = 1.0
Transparent pow = 2.0; Transparent multiplier = 1.0
Last update: 2018-08-10
