Creating a Custom Shader for Post-Processing
Unigine engine allows you to create your own post-effects by writing custom shaders. To write post-effect shaders, you should use the same workflow as for deferred and forward rendering passes: create the material, write vertex and fragment shaders.
This tutorial explains how to create a post-effect material, write shaders for it (both vertex and fragment), add a parameter to the material to be able to specify the value from the UnigineEditor.
Create a Material
As in all other shaders tutorials, you should create the material first. Let's add a new base material to your project.
To create post-effect material, you should specify the post pass for shaders and textures.
The material will have the following structure:
Source code (XML)
<base_material version="2.0" name="custom_post" editable="0">
	<!-- Post-effect shaders -->
	<shader pass="post"
		defines="BASE_POST"
		vertex="shaders/vertex/post.vert"
		fragment="shaders/fragment/post.frag"/>
	<!-- Textures -->
	<texture name="color" pass="post" unit="0" type="procedural"/>
	<!-- Parameters -->
	<parameter name="grayscale_power" type="slider" shared="1" min="0.0" max="1.0"
	flags="max_expand">0.5</parameter>
</base_material>
The key features of the post material are:
  • Added a post pass shaders and textures.
  • Added the shared grayscale_power parameter.
Save the new material as custom_post.basemat file to the assets/Materials folder.
Create Vertex Shader
Since we write a simple shader example, let's write a simple shader like the vertex shader for the deferred rendering pass.
  1. Write the shader code in the plain text editor:
    Source code (UUSL)
    // Include the UUSL header
    #include <core/shaders/common/common.h>
    // Input data struct
    STRUCT(VERTEX_IN)
    	INIT_ATTRIBUTE(float4,0,POSITION)	// Vertex position
    	INIT_ATTRIBUTE(float4,1,TEXCOORD0)	// Vertex texcoords
    	INIT_ATTRIBUTE(float4,2,COLOR0)		// Vertex color
    END
    // Output data struct
    STRUCT(VERTEX_OUT)
    	INIT_POSITION		// Output projected position
    	INIT_OUT(float2,0)	// Texcoords (x and y only)
    END
    MAIN_BEGIN(VERTEX_OUT,VERTEX_IN)
    	// Set output position
    	OUT_POSITION = getPosition(IN_ATTRIBUTE(0));
    	OUT_DATA(0).xy = IN_ATTRIBUTE(1).xy;
    MAIN_END
    // end
    You should add a new line (press Enter) after closing the instruction (after MAIN_END command).
  2. Save the shader file as post.vert to the assets/shaders/vertex folder.
The code of the vertex shader is so simple since we don't need to work with the geometry.
Use the shaders_reload command to reload shaders whilst the engine is running.
Create Fragment Shader
This section contains instruction how to create a fragment shader (also known as pixel shader).
To create the fragment shader for post-process pass, perform the following:
  1. Open a plain text editor, and write the following:
    Source code (UUSL)
    // Include the UUSL fragment shader header
    #include <core/shaders/common/fragment.h>
    // Define the texture of the scene
    INIT_TEXTURE(0,TEX_SCENE)
    // Input values
    STRUCT(FRAGMENT_IN)
    	INIT_POSITION		// Projected position
    	INIT_IN(float2,0)	// Texcoords
    END
    // Define the grayscale_power parameter
    CBUFFER(parameters)
    	UNIFORM float grayscale_power;
    END
    MAIN_BEGIN(FRAGMENT_OUT,FRAGMENT_IN)
    	// Get the UV
    	float2 uv = IN_DATA(0);
    	// Get the scene color
    	float4 scene_color = TEXTURE_BIAS_ZERO(TEX_SCENE,uv);
    	// Calculate the grayscale
    	float3 gray_scene_color = FLOAT3(dot(float3(0.3f, 0.59f, 0.11f), scene_color.rgb));
    	scene_color.rgb = lerp(scene_color.rgb,gray_scene_color,FLOAT3(grayscale_power));
    	OUT_COLOR = scene_color;
    MAIN_END
    // end
  2. Save the shader file as post.frag to the assets/shaders/fragment folder.
Well, let's clarify what is under the hood of this fragment shader:
  • We get the texture which was specified in the post-effect material.
  • By applying a standard grayscale equation, we change the color of the scene.
  • By using lerp function (which performs a linear interpolation), we add the custom parameter to adjust the grayscale power.
Use the shaders_reload console command to reload shaders whilst the engine is running.
Editing the Material
Material has been created, shaders have been written, it's time to use it in the project!
  1. Open UnigineEditor and launch your project.
  2. Create a new material by inheriting from the recently created one in the Materials Hierarchy window.
  3. Open the Settings window by choosing Windows -> Settings from the main menu
  4. In the Settings window choose Runtime -> Render and specify the name of the child post material in the Post Materials field.
    The grayscale post-effect will be applied.
  5. Select your material in the Materials window. Then in the Parameters window select Parameters tab.
    Set up the grayscale post-effect by adjusting the grayscale power parameter.
    The final scene.
Last update: 2018-08-10
