Creating a Custom Shader for Deferred Rendering Pass
In Unigine all the opaque geometry is rendered in the deferred rendering pass. This article explains how to create your own material with shaders (both vertex and fragment) for the deferred rendering pass.
In this article, we create a material for static, dynamic and skinned meshes. We define a heightmap for the vertex shader and an albedo texture for the fragment shader. Also, we calculate normals to ensure proper lighting for our mesh.
Prior Knowledge
Create a Material
The material is the essential thing for rendering: you specify shaders, states, bindings, textures in the material, thus, telling the engine how to render it.
Let's create our own base material (for deferred pass only) and write the vertex and the fragment shaders for it. Perform the following steps to create the material:
  1. In your project folder open the assets/Materials folder.
  2. Create a new custom_mesh_material.basemat file and implement the following base material:
    Source code (XML)
    <!-- Custom mesh material -->
    <base_material version="2.0" name="custom_mesh_material" editable="0" parameters_prefix="m">
    	<!-- States -->
    	<state name="deferred">1</state>
    	<!-- Deferred rendering shaders -->
    	<shader pass="deferred" node="object_mesh_static"
    		deferred="1"
    		defines="BASE_DEFERRED"
    		vertex="shaders/vertex/deferred.vert"
    		fragment="shaders/fragment/deferred.frag"/>
    	<!-- Bindings -->
    	<bind node="object_mesh_dynamic" to="object_mesh_static"/>
    	<bind node="object_mesh_skinned" to="object_mesh_static"/>
    </base_material>
    • We defined a new custom_mesh_material base material with the deferred state.
    • Also we defined shaders (fragment and vertex) for the deferred pass and set the paths to them (we will create both these shader files and a folder in the following sections).
    • Finally, we defined the bindings: types of meshes for which the material can be assigned.
  3. Save the changes.
Create a Vertex Shader
In this section we explain how to create the structure for shaders and how to create the custom vertex shader.
We assign two shaders in out material: vertex and fragment. To create the vertex shader, perform the following:
  1. Create the shaders folder in your project's assets folder.
  2. Inside the recently created folder, create another two folders: vertex for vertex shaders, fragment for fragment shaders.
  3. Open a plain text editor and write the following:
    Source code (UUSL)
    // Include Unified Unigine Shader Language (UUSL) header
    #include <core/shaders/common/common.h>
    // Input data struct
    STRUCT(VERTEX_IN)
    	INIT_ATTRIBUTE(float4,0,POSITION)	// Vertex position
    	INIT_ATTRIBUTE(float4,1,TEXCOORD0)	// Vertex texcoord (uv)
    	INIT_ATTRIBUTE(float4,2,TEXCOORD1)	// Vertex basis tangent
    	INIT_ATTRIBUTE(float4,3,TEXCOORD2)	// Vertex color
    END
    // Our output vertex data struct
    STRUCT(VERTEX_OUT)
    	INIT_POSITION					// Out projected position
    	INIT_OUT(float4,0)				// Texcoord (uv)
    END
    MAIN_BEGIN(VERTEX_OUT,VERTEX_IN)
    	// Get transform with scale and rotation (without translation)
    	float4 row_0 = s_transform[0];
    	float4 row_1 = s_transform[1];
    	float4 row_2 = s_transform[2];
    	// Get Modelview-space transform
    	float4 in_vertex = float4(IN_ATTRIBUTE(0).xyz,1.0f);
    	float4 position = mul4(row_0,row_1,row_2,in_vertex);
    	// Set output UV
    	float4 texcoord = IN_ATTRIBUTE(1);
    	OUT_DATA(0) = texcoord;
    	// Set output position
    	OUT_POSITION = getPosition(position);
    MAIN_END
    // end
    You should add a new line (press Enter) after closing the instruction (after MAIN_END command).
    The code is pretty simple and clear. In the code above we
    • Include the UUSL header.
    • Define the input vertex data structure.
    • Define the output vertex data structure.
    • Start the main program of the shader:
      • Translate the object-space coordinates to clipping space coordinates.
      • Set the output UV.
      • Set the vertex position.
  4. Save the shader file with the deferred.vert name and extension inside the assets/shaders/vertex folder.
Create a Fragment Shader
This section contains instructions on how to create a fragment shader (also known as pixel shader).
To create the fragment shader, perform the following:
  1. Open a plain text editor, and write the following:
    Source code (UUSL)
    // Include the UUSL language header
    #include <core/shaders/common/fragment.h>
    STRUCT(FRAGMENT_IN)
    	INIT_POSITION				// Projected position
    	INIT_IN(float4,0)			// Texcoord (uv)
    END
    MAIN_BEGIN_DEFERRED(FRAGMENT_IN)
    	// Create the G-Buffer and set it
    	GBuffer gbuffer = GBufferDefault();
    	setGBuffer(gbuffer);
    MAIN_END
    // end
    Explanations on fragment shader:
    • We include the UUSL header for fragment shaders.
    • Define the input fragment data struct (where we receive the data from output structure of the vertex shader).
    • Start the main program of the shader, where we create a GBuffer instance for metalness workflow and set it.
  2. Save the shader file with the deferred.frag name and extension to the assets/shaders/fragment folder.
Working with Material
After performing all these steps you can see the recently created shaders in use. They are primitive, and don't provide a nice final image. Anyway, to check their work perform the following steps:
  1. Launch your project in editor mode (or open your world by using UnigineEditor). UnigineEditor will create all necessary .asset files and necessary resources in the data folder.
  2. Open the Materials window. You will see the recently created base material in the list of materials.
  3. Assign the created material to the material ball by dragging it to the object. Or create a primitive (e.g., a sphere) and assign the material to the primitive.
After that you'll get the following result:
It doesn't look good, but it works.
Let's go further and calculate the tangent basis for the mesh and assign textures to it.
Adding Textures to Shaders
Let's add textures to the both shaders: vertex and fragment. In the vertex shader we will use texture as a heightmap and in the fragment as a albedo map.
Editing the Material
First, let's edit our custom base material and add two texture slots.
  1. Open the custom_mesh_material.basemat file from the assets/Materials folder by using plain text editor.
  2. Modify it as follows:
    Source code (XML)
    	<!-- States -->
    		deferred="1"
    	<!-- Bindings -->
    	<!-- Textures -->
    	<texture unit="0" name="albedo" anisotropy="1" shader="fragment" pass="deferred">core/textures/common/white.dds</texture>
    	<texture unit="1" name="height" shader="all" pass="deferred">core/textures/common/white.dds</texture>
    </base_material>
Now the textures will be available for the shaders. We specified the name of the texture, rendering pass, and the path to the default texture.
Editing the Vertex Shader
Now we should edit the vertex shader code and add the texture to the shader.
The best way to add the texture in the shader (an example):
USL
// Initialize the texture slot for a texture named TEX_COLOR
INIT_TEXTURE(0, TEX_COLOR)
It makes changing the number of textures slots easy without correction of the whole shader's code. Let's do it in the vertex shader:
  1. Open the vertex shader deferred.vert file in the assets/shaders/vertex folder by using plain text editor.
  2. Edit the source code in the following way:
    Source code (UUSL)
    // Create a texture sampler
    INIT_TEXTURE(1,TEX_HEIGHT)
    STRUCT(VERTEX_IN)
    END
    STRUCT(VERTEX_OUT)
    	INIT_OUT(float3,1)	// Vertex TBN (X)
    	INIT_OUT(float3,2)	// Vertex TBN (Y)
    	INIT_OUT(float3,3)	// Vertex TBN (Z)
    END
    	// Perfrom Modelview-space transform
    	// Set output UV
    	// Define tangent basis
    	float3 tangent,binormal,normal;
    	// Get normal in object-space
    	getTangentBasis(IN_ATTRIBUTE(2),tangent,binormal,normal);
    	// Transform object-space TBN into camera-space TBN
    	normal = normalize(mul3(row_0,row_1,row_2,normal));
    	tangent = normalize(mul3(row_0,row_1,row_2,tangent));
    	binormal = normalize(mul3(row_0,row_1,row_2,binormal));
    	// Set output TBN matrix
    	OUT_DATA(1) = float3(tangent.x,binormal.x,normal.x);
    	OUT_DATA(2) = float3(tangent.y,binormal.y,normal.y);
    	OUT_DATA(3) = float3(tangent.z,binormal.z,normal.z);
    	// Set the texture
    	float4 height = TEXTURE_BIAS_ZERO(TEX_HEIGHT,texcoord.xy);
    	// Perform the displacement mapping
    	position.rgb += normal * (height.r) * 0.2f;
    MAIN_END
    // end
  3. Save the file.
That's it! Our vertex shader now calculates the normals, gets the texture and performs the displacement mapping. We've added three new output semantics and now we should receive them in our fragment shader.
Editing the Fragment Shader
Now we should edit the fragment shader code and add the albedo texture to the shader.
  1. Open the fragment shader deferred.frag file in the assets/shaders/fragment folder by using plain text editor.
    Source code
    // Adds a texture sampler
    STRUCT(FRAGMENT_IN)
    	INIT_IN(float3,1)			// Vertex TBN (X)
    	INIT_IN(float3,2)			// Vertex TBN (Y)
    	INIT_IN(float3,3)			// Vertex TBN (Z)
    END
    	// Get the UV coords
    	float4 texcoord = IN_DATA(0);
    	// Get the texture data
    	float4 texture_data = TEXTURE(TEX_COLOR,texcoord.xy);
    	// Define the normal of a fragment in tangent-space
    	STATICVAR float3 tangentspace_normal = float3(0.0f,0.0f,1.0f);
    	// Calculate the view-space normal
    	float3 viewspace_normal;
    	viewspace_normal.x = dot(IN_DATA(1),tangentspace_normal);
    	viewspace_normal.y = dot(IN_DATA(2),tangentspace_normal);
    	viewspace_normal.z = dot(IN_DATA(3),tangentspace_normal);
    	viewspace_normal = normalize(viewspace_normal);
    	// Fill G-Buffer: set the calculated normal and albedo color of the texture
    	gbuffer.albedo = texture_data.rgb;
    	gbuffer.normal = viewspace_normal;
    MAIN_END
    // end
  3. Save the file.
Now our shaders are ready to work! Let's see them in action!
We've changed our shaders, so we should reload them by using the shaders_reload console command.
Open the console and execute the shaders_reload command.
Now the result is different: we see the white lit sphere:
It looks much better! But let's go a bit further. Perform the following actions:
  1. Inherit a material from your custom base material (a child material named custom_mesh_material_0 will be created).
  2. Assign the created child material custom_mesh_material_0 to the sphere by dragging it to the object.
  3. Go to the textures tab of the material in the Parameters window.
  4. Choose the albedo and the displacement maps for the material.
Voila! We just created a new deferred material with own shaders which uses two textures for albedo and displacement mapping!
Last update: 2017-12-21
