Common
This tab contains the basic rendering settings.
Distance scale Global distance scale for all distance parameters, such as the world rendering distance, shadow distance, LOD distances etc. This option allows a developer to easily increase or decrease rendering performance by changing the world extent.
Distance scale
Distance scale = 1
Distance scale
Distance scale = 0.3
World distance Distance after which all nodes are not rendered or simulated (infinite by default).
The distance is measured from the camera to the node. If the camera is within node bounds, the node is rendered no matter the World distance set (as in case with a ground on the picture below).
Infinite World distance
World distance = inf
Limited World distance
World distance = 10 units
Physics distance Distance after which physical interactions will not be calculated. All physics -based nodes freeze if the distance between them and the camera is bigger than the Physics distance.
Limited Physics distance
Physics distance = 40 units
Infinite Physics distance
Physics distance = inf
Field distance Distance, at which (and farther) fields are not rendered.
Decal distance Distance after which decals will not be rendered.
Clutter distance Distance after which clutter objects will not be rendered.
Reflection distance Distance after which reflection will not be rendered.
World budget World generation time budget for the Grass and Clutter objects in frames per second.
Physics budget Physics simulation time budget in frames per second.
Render budget Render creation time budget in frames per second. The render budget limits the number of loaded / created graphics resources during frame according to the loading / creation time.
Light distance Distance after which the dynamic lights are not be rendered.
Infinite Light distance
Light distance = inf
Limited Light distance
Light distance = 20 units
Object distance Distance after which objects are not be rendered.
Shadow distance Distance after which the shadows from light sources are not be rendered.
Distance scale
Shadow distance = 1200 units
Distance scale
Shadow distance = 80 units
Reflection color Set reflection color for all meshes with reflective materials.
Wireframe color Set color for meshes wireframe.
Background color Solid color rendered on the scene background. It For example, this option allows to create brighter, richer sky colors with light scattering.
Black background color
Default background color
Blue background color
Blue background
Render Render postprocess materials applied before all other Unigine postprocess (such as HDR, DOF, etc.) are rendered. Several materials are separated by a comma (without whitespace). Custom postprocesses can also be set.
For example, post_filter_scattering is set here. This way, subsurface scattering will be rendered first, and then correctly blurred with DOF.
Composite This field allows to set the name of a custom composite shader. It will be used for the final composition of the full-screen image instead of the default one.
Post Post postprocess materials applied at the end, after all other postprocess (such as HDR, DOF, etc.) are rendered. Such postprocesses, when applied to the screen image, affect HDR flares, glowing areas and so on. Several materials are separated by a comma (without whitespace). Custom postprocesses can also be set.
Here is an example with post_blur_radial material.
Radial blur post material
