Creating Controllable Character
Let's create a playable robot that can move around the Play Area and collide with objects or wall obstacles. Our character will fly above the floor and rotate to face the cursor.
Step 1. Engage Physics for Robot's Model#
The robot with a complex 3D model will represent the playable character in the game. We have already imported the Node Reference with the Skinned Mesh, the flying animation, and materials for the robot.
The robot must be able to move around the Play Area and collide with static and physical objects. In order to do so, it should have a physical body and a collision shape approximating its volume.
  1. Place the imported programming_quick_start\character\robot\robot.node on the floor inside the Play Area by dragging it from the Asset Browser directly to the Editor Viewport.
  2. With the robot node selected click Edit in the Reference section of the Parameters window. The Node Reference shall open and the current selection shall focus on the robot ObjectMeshSkinned node. Now switch to the Physics tab of the Parameters window and assign a Rigid body to the selected ObjectMeshSkinned.
  3. Set LDamping parameter to 5.0 to make sure that the robot will lose speed over time.
  4. Scroll down to the Shapes section and add a Capsule shape to the body.
The capsule shape will be used as an approximation volume for collisions with other objects in the world.
Step 2. Set Up Controls#
We will apply a linear impulse to the body to move the robot with keyboard WASD keys. The robot's motion will be determined according to the camera's orientation. Also, let's restrict the physics-based rotation and vertical movement to avoid unwanted control behavior.
To orient the robot to face the cursor, we will use one of the intersection types called World Intersection. It will trace a line from the cursor position to the floor to get an intersection point that will be used as a reference for the robot's rotation. You can read more about managing various intersections here.
The best way to manage keyboard and mouse inputs, is to use the Input class. It enables you to check the state of the buttons and get the current mouse coordinates. Alternative methods for input handling are described here.
Let's use the C++ Component System to implement this logic. We will create a C++ component and assign it to the robot's node in the world.
  1. To start writing code we should open our project in an IDE. Go to SDK Browser and choose Open Code IDE.
  2. In an IDE create a new C++ class (*.h and *.cpp files) and call it PlayerController. Make sure it inherits from the Unigine::ComponentBase class.
  3. Copy the code below and paste it to the corresponding files in your project and save them in your IDE.
    It is recommended to use Visual Studio as a default IDE.
    PlayerController.h (C++)
    #pragma once
    #include <UnigineGame.h>
    #include <UnigineControls.h>
    #include <UnigineStreams.h>
    #include <UniginePlayers.h>
    #include <UnigineWorld.h>
    #include <UnigineConsole.h>
    #include <UnigineMathLib.h>
    #include <UnigineRender.h>
    class PlayerController : public Unigine::ComponentBase
    	COMPONENT_DEFINE(PlayerController, ComponentBase)
    	COMPONENT_INIT(init);
    	COMPONENT_UPDATE_PHYSICS(updatePhysics);
    protected:
    	void init();
    	void updatePhysics();
    	void move(const Unigine::Math::vec3& direction);
    	Unigine::BodyRigidPtr rigid;
    	Unigine::PlayerPtr player;
    	// a WorldIntersection object to store the information about the intersection
    	Unigine::WorldIntersectionPtr intersection = Unigine::WorldIntersection::create();
    	Unigine::Math::Vec3 pos;
    PlayerController.cpp (C++)
    #include "PlayerController.h"
    REGISTER_COMPONENT(PlayerController);
    void PlayerController::init()
    	player = Game::getPlayer();
    	if (node)
    		rigid = node->getObjectBodyRigid();
    		if (rigid)
    			rigid->setAngularScale(vec3(0.0f, 0.0f, 0.0f)); // restricting the rotation
    			rigid->setLinearScale(vec3(1.0f, 1.0f, 0.0f)); // restricting Z movement
    			rigid->setMaxLinearVelocity(8.0f); // clamping the max linear velocity
    void PlayerController::updatePhysics()
    	if (!Console::isActive())  // do not process input if the console is shown
    		// check if W key is pressed
    		if (Input::isKeyPressed(Input::KEY::KEY_W))
    			move(player->getWorldDirection(MathLib::AXIS::AXIS_Y)); // move forward
    		// check if S key is pressed
    		if (Input::isKeyPressed(Input::KEY::KEY_S))
    			move(player->getWorldDirection(MathLib::AXIS::AXIS_NY)); // move backward
    		// check if A key is pressed
    		if (Input::isKeyPressed(Input::KEY::KEY_A))
    			move(player->getWorldDirection(MathLib::AXIS::AXIS_NX)); // move left
    		// check if D key is pressed
    		if (Input::isKeyPressed(Input::KEY::KEY_D))
    			move(player->getWorldDirection(MathLib::AXIS::AXIS_X)); // move right
    		// finding the positions of the cursor and the point moved 100 units away in the camera forward direction
    		ivec2 mouse = Input::getMousePosition();
    		Vec3 p0 = player->getWorldPosition();
    		Vec3 p1 = p0 + Vec3(player->getDirectionFromMainWindow(mouse.x, mouse.y)) * 100;
    		ObjectPtr obj = World::getIntersection(p0, p1, 1, intersection); // the first bit of the intersection mask is set to 1, the rest are 0s
    		// finding the intersection position, creating a transformation matrix to face this position and setting the transform matrix for the body preserving current angular and linear velocities
    		if (obj && rigid)
    			pos = intersection->getPoint();
    			pos.z = rigid->getTransform().getTranslate().z; // project the position vector to the Body Rigid pivot plane
    			Mat4 transform = Math::setTo(rigid->getTransform().getTranslate(), pos, vec3_up, AXIS::AXIS_Y);
    			rigid->setPreserveTransform(transform); // turn the character's body
    // moving the rigid body with linear impulse in the specified direction
    void PlayerController::move(const Unigine::Math::vec3& direction)
    	// direction is a normalized camera axis vector
    	if (rigid)
    		rigid->addLinearImpulse(direction);
  4. Before you can use C++ components you should initialize the Component System. Modify the init() method of the AppSystemLogic class as shown below (AppSystemLogic.cpp file). Also enable automatic NodeReference unpacking for convenience.
    AppSystemLogic.cpp (C++)
    int AppSystemLogic::init()
    	// unpack node references to find child nodes by name
    	World::setUnpackNodeReferences(true);
  5. Build and run the project via your IDE (press Ctrl + F5 in Visual Studio), the Component System will generate a property-file for the component.
  6. Switch back to UnigineEditor and select the robot node (ObjectMeshSkinned) in the World Nodes window. Then click Add New Property in the Parameters window and assign the newly generated PlayerController property.
    Make sure you assign the property to the ObjectMeshSkinned node inside the NodeReference!
Step 3. Finalize and Run#
  1. Turn off the Intersection detection for every surface of the robot node to ignore intersections with the robot's own surfaces, as we do not want it in our robot's rotation implementation.
  2. For every wall object in the world, go to the Parameters window and find the Surfaces section in the Node tab. Select the box surface of the mesh and open an Intersection Mask window. Uncheck the first Intersection Mask 0 bit to make sure that walls will not affect the player's character turning.
  3. To make the cursor always visible, go to Windows->Settings->Controls section, change the Mouse Handle mode to User. You can also control the cursor via API.
  4. Save changes to the world and the robot via File->Save World (or press Ctrl+S hotkey).
Build and run the game in your IDE to try out the robot's controls.
To run the debug version of your project from SDK Browser, enable the Debug mode in Customize Run Options.
Last update: 2024-08-16
