Docker Container Configuration
This article describes the Docker container configuration process. Docker enables you to develop or run your UNIGINE-based application in different environments in isolation inside the container. Your computer needs to have an NVIDIA graphic card and Linux system with Ubuntu to replicate all necessary steps.
To work within other distributions, like Amazon, Open Suse, Debian, Centos, or RHEL, please refer to the NVIDIA Container Toolkit documentation.
System Requirements#
You need to shut down all the programs playing sound. The ALSA driver should be installed in the system to play the sound correctly.
The Docker daemon binds to a Unix socket, not a TCP port. By default it's the root user that owns the Unix socket, and other users can only access it using sudo (read more). The Docker daemon always runs as the root user.
If you don't want to preface the docker command with sudo, create a Unix group called docker and add users to it (read more). When the Docker daemon starts, it creates a Unix socket accessible by members of the docker group.
Docker Configuration#
To configure Docker perform the following steps:
- Install NVIDIA Container Toolkit
- Get the Docker container image or assemble it yourself.
- Run a Docker container in test mode.
NVIDIA Container Toolkit Installation#
Configure NVIDIA Container Toolkit according to its configuration documentation. Install the package repository and the GPG key, type the command line for that:
Output$ distribution=$(. /etc/os-release;echo $ID$VERSION_ID) \ && curl -fsSL https://nvidia.github.io/libnvidia-container/gpgkey | sudo gpg --dearmor -o /usr/share/keyrings/nvidia-container-toolkit-keyring.gpg \ && curl -s -L https://nvidia.github.io/libnvidia-container/$distribution/libnvidia-container.list | \ sed 's#deb https://#deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://#g' | \ sudo tee /etc/apt/sources.list.d/nvidia-container-toolkit.list
Install nvidia-docker2:
Output$ sudo apt-get update $ sudo apt-get install -y nvidia-docker2
Restart Docker:
Output$ sudo systemctl daemon-reload $ sudo systemctl restart docker
Preparing Container Image#
There is a ready-to-use container image that we have prepared for you on the Docker Hub - check out the following link run-unigine-in-docker and use the following command:
docker pull unigine/run-unigine-in-docker
In case for any reason instead of using the container image from the Docker Hub you want to prepare and assemble your container image manually please follow the instructions in the spoiler below:
Create a folder to work with the container:
Output$ mkdir ~/unigine-in-docker
Create a Dockerfile text file inside the unigine-in-docker/ folder:
Output$ cd ~/unigine-in-docker $ touch Dockerfile
Add the following lines to the Dockerfile file and save it:
OutputFROM nvidia/opengl:base-ubuntu20.04 VOLUME /tmp/.X11-unix RUN apt update && apt upgrade -y # linux-headers- hardcoded, if it don't build - try update version of linux-headers RUN DEBIAN_FRONTEND=noninteractive apt-get update && DEBIAN_FRONTEND=noninteractive apt install -y \ python3 \ wget gnupg \ xvfb \ x11-xserver-utils \ python3-pip \ libegl1-mesa \ libgl1-mesa-dev \ libxv1 \ gcc g++ make ccache \ libxrandr-dev \ libxinerama-dev \ libopenal1 \ libxrender-dev \ libxext-dev \ libc6-dev \ libx11-dev \ libxi-dev \ libxml2-dev \ cmake \ nano vim \ lshw \ libglu1-mesa \ mesa-utils \ glmark2 \ xxd \ # for sdk bro2 \ libxcb-shape0 \ libxcb-xkb1 \ libxcb-icccm4 \ libxcb-image0 \ libxcb-keysyms1 \ libxcb-render-util0 \ libxkbcommon-x11-0 \ linux-headers-5.4.0-135-generic \ lxterminal \ # sound \ alsa-base \ alsa-utils \ libsndfile1-dev COPY ./asound.conf /etc/ RUN python3 -m pip install pyinotify ENV XDG_RUNTIME_DIR=/tmp/.X11-unix # install dotnet and runtime # if it don't build - try to find more recent versions of dotnet at https://dotnet.microsoft.com/en-us/download/dotnet/6.0 RUN wget -O dotnet.tar.gz https://download.visualstudio.microsoft.com/download/pr/01292c7c-a1ec-4957-90fc-3f6a2a1e5edc/025e84c4d9bd4aeb003d4f07b42e9159/dotnet-sdk-6.0.418-linux-x64.tar.gz RUN wget -O dotnet-runtime.tar.gz https://download.visualstudio.microsoft.com/download/pr/b63daa46-51f4-480e-ad03-ef2c5a6a2885/ae059763456991305109bf98b3a67640/aspnetcore-runtime-6.0.26-linux-x64.tar.gz RUN mkdir /usr/local/etc/dotnet-sdk-6.0 RUN tar -xzf dotnet.tar.gz -C /usr/local/etc/dotnet-sdk-6.0 RUN tar -xzf dotnet-runtime.tar.gz -C /usr/local/etc/dotnet-sdk-6.0 RUN rm -rf /usr/bin/dotnet RUN ln -s /usr/local/etc/dotnet-sdk-6.0/dotnet /usr/bin/dotnet # path to libraries ENV LD_LIBRARY_PATH="/opt/project/bin"
Create a new asound.conf file:
Output$ sudo vi asound.conf
Write the following script to the asound.conf file:
Outputpcm.!default { type plug slave { pcm "hw:0,0" } } ctl.!default { type hw card 0 } pcm.mixed-analog { type plug slave.pcm "dmix-analog" hint { show on description "Mixed Analog Output - Use analog outputs, converting samples, format, and rate as necessary. Allows mixing with system sounds." } } # Control device (mixer, etc.) for the card ctl.mixed-analog { type hw card 0 }
Assemble the Docker image (inside the unigine-in-docker folder):
Output$ docker build --rm --tag run_unigine_in_docker:latest -f Dockerfile .
Docker Test Run#
Launch the container in trial mode to view GPU characteristics:
Output$ cd ~/unigine-in-docker/ $ docker run -it --rm --network host \ --runtime=nvidia --gpus 0 -e NVIDIA_VISIBLE_DEVICES=0 \ -e DISPLAY=${DISPLAY} \ -e NVIDIA_DRIVER_CAPABILITIES=display,compute \ -v /tmp/.X11-unix:/tmp/.X11-unix \ run_unigine_in_docker:latest \ /bin/bash # nvidia-smi
Check selected GPU drivers with the following command: glxinfo | grep "OpenGL". You will see the full information about your GPU. Or use the command glxinfo | grep "OpenGL renderer" to display the model name of the GPU used. An example of the response:
Using Docker Container#
As You have successfully built and run GPU-accelerated Docker container you can do the following:
