Creating Routes within Connected Navigation Sectors
The example guides you through the process of setting up a scene with a navigation area of a complex form and calculating 2D and 3D routes within it.
In UNIGINE, only Navigation Sectors can be used for calculation of both 2D and 3D routes. The navigation sectors can be easily rearranged, disabled, or enabled on the fly. Moreover, you can specify the sectors that can participate in pathfinding and exclude others. In order to form a unified navigation area, the sectors must intersect with each other.
Let's consider these features in detail.
Preparing Scene#
Our scene will include a navigation area that consists of multiple intersecting navigation sectors and primitives indicating the start and destination points of a route.
  1. Create an empty C# project via SDK Browser.
  2. Open it in UnigineEditor and remove the unnecessary default nodes.
  3. In the Menu bar, choose Create -> Navigation -> Navigation Sector and place the node above the plane.
    To facilitate working with the navigation sectors, activate gizmos for Navigation nodes in the Helpers Panel.
  4. Add 8 more navigation sectors to the scene by cloning (Ctrl+D) the existing sector and place them as follows:
    You can position the sectors manually using manipulators or by specifying the exact position via the Parameters window.
  5. In the Parameters window, adjust the positions of the nodes along the Z axis so that they are all positioned at the same level above the plane.
  6. Add a new sector and adjust its Size in the Parameters window to give it a parallelepiped shape.
    At this step, you can approximately set the size of the sector. However, you may need to adjust it later to prevent excluding the navigation sector from pathfinding.
  7. Connect the cuboid-shaped navigation sectors: place the new sector between them.
    For 2D routes, the height difference between the intersecting sectors must not exceed the maximum height set for the 2D route; otherwise, these sectors are discarded from pathfinding. In addition, the intersection area must exceed the radius and height of the route. So, it may be necessary to adjust the size and position of the sector to correct the intersection area.
  8. Add 11 more navigation sectors that connect the cuboid-shaped sectors by cloning (Ctrl+D) the existing sector and place them as follows:
  9. Organize the created navigation sectors in a hierarchy. It will allow you to manage the navigation area as a single node. Select all the navigation sectors, right-click, and choose Group in the drop-down list or press Ctrl+G.
  10. Add 2 nodes to be used as the start and destination points of the route. We will create 2 boxes (Create -> Primitives -> Box), rename them start and finish, and then place them inside the navigation sector as pictured below.
Creating Component for 2D Route Calculation#
The created navigation sectors only provide the area within which routes are calculated. The routes themselves must be created from the code. So, let's create the corresponding C++ component for 2D route calculation.
If you have completed the previous guide on creating routes within a simple navigation sector, you can skip this step and copy the implemented Route2D component to the source folder of your project (both the *.h and *.cpp files).
Add a new Route2D class inherited from the ComponentBase class (the *.h and *.cpp files) to the project. The class name will be used as the property name.
Implementing Component Logic#
If you have copied the Route2D component on the previous step, you can skip this one.
  1. In the Route2D.h file, declare a component class, parameters, and a route:
    • Two parameters that will accept nodes between which a route should be calculated.
    • Route color.
    #pragma once
    // derive the component from the ComponentBase class
    class Route2D : public ComponentBase
    	// declare constructor and destructor and define a property name. The Route2D.prop file containing all parameters listed below will be saved in your project's data folder
    	COMPONENT_DEFINE(Route2D, ComponentBase);
    	COMPONENT_INIT(init);
    	COMPONENT_UPDATE(update);
    	COMPONENT_SHUTDOWN(shutdown);
    	// declare parameters of the component
    	PROP_PARAM(Node, startPoint, NULL);
    	PROP_PARAM(Node, finishPoint, NULL);
    	PROP_PARAM(Color, routeColor, vec4_zero);
    	void init();
    	void update();
    	void shutdown();
    	// declare a route
    	PathRoutePtr route;
  2. In the Route2D.cpp file, register the component.
    #include "Route2D.h"
    REGISTER_COMPONENT(Route2D);
  3. Create a route and set the radius and height for the point which will move along the route in the init() method. Before creation, check if the nodes to be used as the start and finish points are specified.
    #include <UnigineNode.h>
    #include <UnigineConsole.h>
    #include <UnigineLog.h>
    void Route2D::init() {
    	// check if the start and destination nodes are correctly specified via the component interface
    	if (startPoint && finishPoint)
    		// create a new route
    		route = PathRoute::create();
    		// set a radius and height for the point which will move along the route
    		route->setRadius(0.1f);
    		route->setHeight(0.1f);
  4. To enable displaying the calculated route at run time, turn on the Visualizer. Additionally, you can output console messages to the application screen. Add the following logic to the init() function:
    Console::setOnscreen(true);
    Visualizer::setEnabled(true);
  5. In the update() function, calculate the route from the start to destination node:
    void Route2D::update() {
    		route->create2D(startPoint->getWorldPosition(), finishPoint->getWorldPosition());
    		if (route->isReached())
    			// if the destination point is reached, render the root in a specified color
    			route->renderVisualizer(routeColor);
    		else
    			Log::message("PathRoute not reached yet\n");
    Here the route is recalculated each frame. However, it is not optimal for application performance. Instead, you can calculate the route once per several frames: pass a delay to the create2D() function as the third argument.
  6. Implement the shutdown() function to disable the visualizer and onscreen console messages:
    void Route2D::shutdown() {
    	Console::setOnscreen(false);
    	Visualizer::setEnabled(false);
  7. The component is registered automatically by the Component System upon its initialization. However, you should add the following to the AppSystemLogic::init() method:
    #include "AppSystemLogic.h"
    int AppSystemLogic::init()
  8. Build the project and run it once to generate the property for the Route2D component. It will be located in the data/ComponentSystem folder.
Here is the full code of the component:
Route2D.h
#pragma once
	void init();
	void update();
	void shutdown();
	// declare a route
	PathRoutePtr route;
Route2D.cpp
		else
Assigning Component#
When the component logic is implemented and the property is generated, you should assign it to a node.
  1. In UnigineEditor, select Create -> Node -> Dummy and place it in the navigation area.
  2. Select the dummy node and assign the Route2D property to it in the Parameters window.
  3. In the component parameters, specify the start and finish static meshes in the Start Point and Finish Point fields.
  4. Change the Route Color, if necessary.
Visualizing Navigation Area#
To clearly show how the path is built inside the navigation area, let's implement the AreaVisualizer component that enables displaying the navigation area gizmo at run time:
  1. Add a new AreaVisualizer class inherited from the ComponentBase class (the *.h and *.cpp files) to the project.
  2. Implement the logic:
    #pragma once
    class AreaVisualizer : public ComponentBase
    	COMPONENT_DEFINE(AreaVisualizer, ComponentBase);
    	void update();
    #include "AreaVisualizer.h"
    REGISTER_COMPONENT(AreaVisualizer);
    void AreaVisualizer::update()
    	// display the navigation area gizmo
    	node->renderVisualizer();
  3. Build the project and run it once again to generate the property for the AreaVisualizer component.
  4. Assign the component to each navigation sector forming the navigation area.
Trying Out#
Launch the application to check the result.
If the route is not reached, try to modify the route parameters (a point height and/or radius) or adjust the size of the sector(s) or intersection area(s), as the point moving along the route must fit the size of the navigation area.
Excluding Sectors from Pathfinding#
Sometimes, it might be necessary to ignore some navigation sectors during pathfinding. For this purpose, you can set the Navigation mask for both the navigation sector and the route so that they don't match.
  1. Select one of the navigation sectors participating in pathfinding.
  2. Change its Navigation Mask in the Parameters window.
  3. Run the application to check how the route is recalculated.
Modifying Component for 3D Route Calculation#
The navigation sector also enables the calculation of 3D routes, with some features that differ from the 2D routes:
  • For 3D routes, the point moves in 3 dimensions.
  • Only the radius set for the point matters: if the radius set for the point is greater than the size of the navigation sector, it will be discarded.
  • The maximum height set for the route determines the upper limit of the point's vertical movement.
You can force the Route2D component to calculate a 3D route within the same navigation area by changing a single line of the code. Replace the create2D() function call with the following:
Source code (C#)
route->create3D(startPoint->getWorldPosition(), finishPoint->getWorldPosition());
Then build the project and run it once again to re-generate the property for the Route2D component.
Run the application to check the result.
Last update: 2024-08-16
