Create Nodes
The Create Nodes section of the C# Component Samples demo contains a set of samples demonstrating the following:
- Create_And_Delete — creating and deleting nodes via code
- Create_Primitives — creating parametric primitives via code
Accessing Demo Source Code#
- Find the C# Component Samples demo in the Demos section and click Install (if you haven't installed it yet).
- After successful installation the demo will appear in the Installed section, and you can click Copy as Project to create a project based on this demo.
- In the Create New Project window, that opens, enter the name for your new project in the corresponding field and click Create New Project.
- Now you can click Open Code IDE to check and modify source code in your default IDE, or click Open Editor to open the project in the UnigineEditor.
