Separate Images Output with Separate Plugin
The Separate plugin is used to create a separate window for each eye. It can be used with any devices that support separate images output, e.g. for 3D video glasses or helmets (HMD)
  • The Separate plugin is available only on DirectX 11 graphics API. So it can be used under Windows only.
  • This plugin cannot be used in a Qt-based application.
Separate can be rendered in both the windowed and the full-screen mode.
Launching Separate#
To use the plugin, specify the extern_plugin command line option and STEREO_SEPARATE define on the start-up:
Shell commands
main_x64d -extern_plugin "UnigineSeparate" -extern_define STEREO_SEPARATE
Also you can create a new project with the Separate plugin support by checking the Dual output stereo 3D option on the New Project tab of the UNIGINE SDK Browser.
The engine automatically loads the appropriate version of the library depending on the specified main application. So you can use 64-bit debug or release version of the library.
The Separate plugin cannot be used with:
Customizing Separate#
Unigine-based application can be used with any custom device that supports an output of separate image pairs. You simply need to do the following:
  1. Define the application behaviour when the STEREO_SEPARATE define is set on the start-up or in the configuration file:
    #ifdef STEREO_SEPARATE
    	// implement your code here
    #endif
  2. Implement the input device interface using an extensible C++ API.
Stereo settings that control eye separation and distance to the zero parallax plane are added to GUI by data/core/scripts/system/stereo.h script and can be controlled from there.
Last update: 2024-01-10
