Obstacle Capsule
The Obstacle Capsule is a capsule-shaped obstacle that is detected and bypassed by other objects during pathfinding. The Obstacle Capsule can be added, for example, for the capsule-shaped nodes (trunks, columns, chimney shafts and so on) that are placed inside a navigation area and should be bypassed.
An Obstacle Capsule and a fur
The size of the Obstacle Capsule is set using the following parameters:
  • Radius — the radius of the cylinder and hemispheres of the capsule.
  • Height — the height of the cylinder of the capsule.
  • The ObstacleCapsule class to manage capsule obstacles via API
    • obstacle_00
    • route_01
    • route_02
Adding Obstacle Capsule#
To add an Obstacle Capsule to the scene via UnigineEditor:
  1. Run UnigineEditor.
  2. On the Menu bar, click Create -> Navigation -> Obstacle Capsule.
A new Obstacle Capsule is added to UnigineEditor and you can edit it via the Parameters window. See also the example on obstacle usage.
Editing Obstacle Capsule#
On the Node tab of the Parameters window, you can adjust the following parameters of the Obstacle Capsule:
Obstacle Mask The Obstacle mask of the Obstacle Capsule must match the Obstacle mask of the route that is calculated during pathfinding. Otherwise, the obstacle is not taken into account during pathfinding. Also by using the Obstacle mask, you can specify Obstacle Capsule that should be ignored during pathfinding.
Radius Radius of the capsule, in units.
Height Height of the capsule, in units.
Last update: 2023-12-19
