Brush Tool
Brush tool (B hotkey) is used for painting arbitrary shapes on a texture.
Settings#
All available settings are described in the Texture Editor article. However, there is a specific Draw Blend Mode parameter that sets a blending mode for the brush:
  • Alpha Blend — override the existing color with the current color.
  • Add — add the current color to the existing color value. This mode can be useful when painting a height map.
    Alpha Blend Mode
    Add Mode
  • Minimum — override the existing color with the current color only if it has a lower value.
  • Maximum — override the existing color with the current color only if it has a higher value. This mode can be used, for example, when you need to increase low values in a height map by no more than a certain value.
    Minimum Mode
    Maximum Mode
Last update: 2023-12-19
