Check this video from the series of video tutorials on the terrain generation using Sandworm:
Terrain generation is a complex task and may require substantial time depending on the area size and data resolution. Sandworm allows using distributed computing to generate terrain.
Distributed computing makes sense when used for speeding up terrain generation that takes more than an hour. Applying distributed computing to generate a small terrain area with low-detail data (10 meters or more per pixel) may be unprofitable at all.
The concept is to use several computers united into a network, one of which is Master and assigns tasks, and the other are Workers that perform portions of work (processing of source data) assigned to them. UnigineEditor with the Sandworm tool and a terrain project should be open on Master, while Workers run the console application. Source files (geodata) and common cache shall be stored in a shared folder. If a Worker still has available resources, additional processes may be run on it and participate in terrain generation immediately, i.e., without restarting the generation process. Master creates the asset based on the result.
All workstations performing computations for a certain terrain generation job must be running on the same operating system (Windows or Linux). UNIGINE SDK version should also be the same.
Participants of the process:
Master
Computer that manages the whole generation process, forms the task pool, and distributes tasks between Workers. Master tracks all connected Workers and assigns tasks to them. Master itself also performs calculations. Master is run via Sandworm.
Worker
Computer connected over the network to Master and performing specific tasks assigned by Master. Worker is enabled by running bin/SandwormNode_x64.exe.
The number of Workers connected to one Master is not limited (as long as the network bandwidth allows that).
Launching Order#
Before launching any of the network participants, disable Microprofile for it — in \data\configs\default.user, set:
Source code
<microprofile_enabled>0</microprofile_enabled>
Otherwise, every instance would run Microprofile, causing memory waste.
You can launch Master and Workers in any sequence.
You can run additional Workers after the terrain generation process has started, and Master will distribute jobs for them.
One machine can have several Workers running. A Worker can have several processes (forks) that are activated via the menu on Master.
Using Distributed Generation#
Workflow:
  1. Prepare your environment.
    Connect all computers to the network. It is recommended to use a network with at least 1 Gb bandwidth. Otherwise, you may experience network lags (see the Troubleshooting section). Check that your network doesn't block broadcasting, otherwise distributed computation will be unavailable.
    It is recommended to use an SSD drive to store the generation cache and output files. If an HDD is used, the generation performance is significantly lower due to multiple read/write and head positioning operations.
  2. On each Worker computer, run the Worker console application.
    The versions of binary executable files must be the same on all computers.
  3. On the Master computer:
    • Run UnigineEditor and open the Sandworm tool (Tools -> Sandworm).
    • Open the *.sworm asset you are going to generate and configure the generation settings.
    • Enable the Distributed option and specify the Master's settings. Save the project configuration.
    • Click the Generate button. The window with the list of available Workers will open:
      Distributed Generation Window
      If you regenerate the project, this window will appear after the warning on losing any manual modifications.
      As soon as this window is open, Workers start parsing the shared source data and generating cache. In the end of this process, the console message Worker: Ready To Import is displayed.
    • Clicking the right mouse button on a Worker makes the following options available:
      Worker Options
      Worker Options
      Create Fork Creates one more process on the same Worker.
      Best Practice
      We estimate a reasonable number of forks as 4 to 6. Higher values reduce the Worker's performance.
      Shutdown Removes the fork or Worker from the list.
      Clear Cache Clears the Worker's local cache.
      Set the number of forks you need and click Generate.
  4. During the generation process, you can connect more Workers, if necessary: run the console application on a Worker (even if this Worker is already running one or several). This console application will automatically connect to Master, and Master will assign a process to this Worker.
  5. When the terrain generation is completed, disable all Worker processes.
Setting Up the Master#
To set up Master, enable Distributed Generation in Generation Settings: toggle on the Enabled option.
Master settings:
Enabled If toggled on, distributed computing is enabled for the terrain generation, and the machine running the Editor with Sandworm is Master.
Broadcast Port Port for listening to Sandworm by Workers.
Server Port Port used for information exchange.
Workload on Master Percentage of terrain generation performed by Master.
All sources and project cache should be stored in a shared location accessible by both Master and all Workers. The path to this location should be identical on Master and Workers.
Setting Up a Worker#
Worker should have the same version of OS and UNIGINE SDK as Master.
To set up a Worker:
  1. Create a new UNIGINE project on a Worker computer with the corresponding project feature enabled:
    Enabling a Worker application
  2. Run the SandwormNode_x64.exe console application stored in the bin/ folder of your project. The message that Worker is ready should appear in console:
    Worker is ready for generation
  3. Set the path for storing the local cache using the --sw_local_cache_path console command.
  4. Use --sw_broadcast_port, if you want to change the default broadcast port.
  5. Worker detects Master on the network, connects to it, downloads the scene, prepares all layers (checks their accessibility), and is ready for terrain generation.
Worker application is running and ready for terrain generation
You can run multiple console applications on one machine and/or fork one Worker via Master to create more processes.
  • Operating System versions on Master and Workers should be identical.
  • The SDK version of the Editor run on Master should be the same as the version of the console app (including precision).
  • Development/Release version of SDK does not matter.
When the terrain generation is completed and you don't need Workers anymore, close the console application on Workers or shut down processes via Master.
Generating Landscape in Headless Mode#
A landscape created in Sandworm project can also be generated in the Headless mode, without running UNIGINE Editor.
To do that:
  1. Configure a UNIGINE project to enable the corresponding feature:
  2. Create and configure a Sandworm project in the Editor, then close the Editor.
  3. Execute the following command from the command line to start the generation process:
    Shell commands
    PS D:\projects_location\unigine_project\bin> .\SandwormNode_double_x64.exe --sw_generate project_name.sworm
    where project_name.sworm is your Sandworm project name as shown in the Editor.
The landscape is generated into the world that has been set as the export world in the output settings. Any TMS sources used in the project are also downloaded before starting the generation process.
The Headless mode doesn't work with distributed computing.
Troubleshooting#
  • If the network latency is too large despite 1Gb bandwidth or higher, this can be caused by a 100 Mb or 10 Mb device connected to the network. Data exchange rate drops down to the maximum rate supported by such device, slowing down the generation speed.
  • Check that your projects on Master and Workers use the same precision (double or float), the same engine versions, and the same GDAL versions, otherwise the Workers would display the Different Builds error.
  • Use SSD to store shared source data and cache.
  • Add the application to the antivirus exclusions, as it may reduce performance.
  • Check that network ports used by Master and Workers are allowed by the firewall.
Last update: 2024-04-19
