This example shows how to create a cloth pinned to two dummy bodies using the particles joints. The cloth falls down and rests on a sphere, which illustrates the cloth ability to change its form.
Falling cloth
To implement this, we need to perform the following:
  • Create a cloth and set its parameters.
  • Create two Dummy Objects that can hold the cloth. They also should have a body so that we can connect a cloth to them using joints.
  • Create a sphere that is not a physical body (so that it would not drop and roll away), but is a collider, so our cloth will not fall through.
We are going to create functions for each participant of the example and then use these functions in init() to create the required objects.
Creating a Cloth#
We create a plane that will represent a cloth — the Dynamic Mesh should be used to allow the cloth change at run time. Here we use the Primitives class to create a plane. You can also try to use your mesh instead, just make sure it complies with the triangulation requirements.
Then we assign the Cloth body to the created Dynamic Mesh and specify the required Cloth body parameters (mass, friction, restitution, etc) and the object parameters (transformation, color, name).
The whole function is as follows:
ObjectMeshDynamicPtr createBodyCloth(const char* name, float width, float height, float step, float mass, float friction, float restitution, float rigidity, float lrestitution, float arestitution, int num_iterations, const vec4& color, const Mat4& tm)
	//assigning a cloth body to the dynamic mesh object and setting the cloth parameters
	BodyClothPtr body = BodyCloth::create(OMD);
	body->setMass(mass);
	body->setFriction(friction);
	body->setRigidity(rigidity);
	OMD->setWorldTransform(tm);
	OMD->setName(name);
	return OMD;
Using this function we create a cloth in the init() method.
Hanging the Cloth in the Air#
We need to fix one edge of the cloth in the air, otherwise it will unpredictably drop down, and there might be no contact with the sphere at all. This task is easily solved by using Dummy Object. We also assign the Dummy body to it, as joints may connect bodies only.
ObjectDummyPtr createBodyDummy(const char* name, const vec3& size, const vec3& pos)
	// creating a dummy object
	// setting parameters
	dummy->setName(name);
	//assigning a dummy body to the dummy object
	BodyDummy::create(dummy);
	return dummy;
	return dummy;
Using this function we create two points in the init() method and pin the cloth to them using the Particles joint:
// creating 2 dummy bodies to which the cloth will be attached
Creating a Sphere#
A sphere is used as a prop to demonstrate how the cloth would cover it, thus there's no need to make it physical. We only need to enable collision for its surface, otherwise the cloth would pass through the sphere without any interaction.
ObjectMeshDynamicPtr createSphere(const char* name, float radius, const vec4& color, const vec3& pos)
	OMD->setName(name);
	OMD->setCollision(1, 0);
	return OMD;
Using this function we create a sphere in the init() method.
Code Sample#
The complete code sample is provided below.
In the AppWorldLogic.h file, define smart pointers for the objects.
#include <UnigineLogic.h>
#include <UnigineStreams.h>
#include <UnigineObjects.h>
#include <UniginePlayers.h>
class AppWorldLogic: public Unigine::WorldLogic
Add the following code to the AppWorldLogic.cpp file.
#include "AppWorldLogic.h"
#include "UnigineGame.h"
#include "UnigineObjects.h"
	OMD->setName(name);
	return OMD;
	return dummy;
	OMD->setName(name);
	return OMD;
int AppWorldLogic::init()
	Game::setPlayer(player);
Last update: 2024-04-19
