VR Sample
VR sample based on VR template showcases the capabilities of the UNIGINE 2 Engine for VR applications. In this demo, you will find yourself in the middle of the scene that is similar to the one you see when you open a default UNIGINE world. The scene contains a table with a set of interactive objects, which you can manipulate via controllers. Among these objects, you'll find a laser pointer, which works as a real one. You can move and teleport around the scene. Moreover, you can interact with GUI elements using controllers.
Features#
  • Based on VR template
  • VR support (Oculus Rift and HTC Vive/OpenVR)
  • A set of physical objects that can be manipulated via controllers
  • An interactive laser pointer object
  • Teleportation around the scene
  • Interaction with GUI objects via controllers
Accessing Demo Source Code#
  1. Find the VR Sample demo in the Demos section and click Install (if you haven't installed it yet).
  2. After successful installation the demo will appear in the Installed section, and you can click Copy as Project to create a project based on this demo.
  3. In the Create New Project window, that opens, enter the name for your new project in the corresponding field and click Create New Project.
  4. Now you can click Open Code IDE to check and modify source code in your default IDE, or click Open Editor to open the project in the UnigineEditor.
Last update: 2023-06-23
