Oil Platform Demo
Offshore oil rig demo showcases global water (ObjectWaterGlobal) capabilities.
Features#
  • Beaufort scale 0-12
  • Vessels and buoys floating on the water surface
  • Interactive helicopter mode
  • Hardware tessellation for water geometry
  • Multiple point lights with batching
Accessing Demo Source Code#
  1. Find the Oil Platform Demo demo in the Demos section and click Install (if you haven't installed it yet).
  2. After successful installation the demo will appear in the Installed section, and you can click Copy as Project to create a project based on this demo.
  3. In the Create New Project window, that opens, enter the name for your new project in the corresponding field and click Create New Project.
  4. Now you can click Open Code IDE to check and modify source code in your default IDE, or click Open Editor to open the project in the UnigineEditor.
Last update: 2023-06-23
