Widgets
The Widgets samples demonstrate various widget use cases:
  • Widget Manipulator implementation shows how to use Engine manipulators to move, rotate, or scale the currently selected object. You can also lock/unlock manipulator axes restricting current transformations and switch between local and world coordinates.
  • Widget Target Marker is an implementation of a HUD with a marker always pointing to the target, when it is within the field of view, or displaying an arrow pointing the direction to the target when it's out of sight (aligned with the screen borders).
Accessing Demo Source Code#
  1. Find the Widgets demo in the Demos section and click Install (if you haven't installed it yet).
  2. After successful installation the demo will appear in the Installed section, and you can click Copy as Project to create a project based on this demo.
  3. In the Create New Project window, that opens, enter the name for your new project in the corresponding field and click Create New Project.
  4. Now you can click Open Code IDE to check and modify source code in your default IDE, or click Open Editor to open the project in the UnigineEditor.
Last update: 2023-06-23
