Sandworm (Experimental)
render_composite
A render_composite material allows you to apply the following full-screen postprocesses selectively (on per-material basis) rather then to the whole screen using the Auxiliary buffer:
This article is deprecated and will be updated in further UNIGINE updates.
Render composite
Material excluded from DOF
Usage#
To apply render_composite material, follow these steps:
  1. Set it (or a material inherited from it) in Render settings -> Composite shader field.
  2. Make sure that Main menu ->Render tab -> Auxiliary buffer option is checked.
    Auxiliary buffer should be enabled
  3. Go to the surface material. Set States tab ->Passes -> Auxiliary pass and set itDefault. It means that the material is rendered into the auxiliary color buffer.
    Enable Auxiliary pass for the material that should be postprocessed
It is also possible to mask materials for two postprocesses using surface material -> Parameters -> Auxiliary Color (see blur_mask and dof_mask below).
States#
auxiliary_mode Specifies if the surface (with Auxiliary pass enabled) should be rendered with the additional color multiplier:
  • Skip - additional color is not rendered
  • Overlay - color multiplier is applied
Overlay mode for Auxiliary buffer
Overlay mode
blur_mask Mask to exclude objects from Motion blur.
  • Skip - all materials are rendered blurred.
  • red - materials that have Auxiliary Color with non-zero Red channel value are excluded from motion blur.
  • green - materials that have Auxiliary Color with non-zero Green channel value are excluded from motion blur.
Yellow material is excluded from motion blur
dof_mask Mask to exclude objects from DOF effect.
  • Skip - all materials are rendered with DOF effect applied.
  • red - materials that have Auxiliary Color with non-zero Red channel value are rendered without DOF effect (non-blurred).
  • green - materials that have Auxiliary Color with non-zero Green channel value are rendered without DOF effect (non-blurred).
Green material without DOF effect
Last update: 2020-11-24
