particles_05
This article describes the data/samples/objects/particles_05.cpp sample.
The particles_05 sample demonstrates how to create 2 continuous flows of particles emitted by the shift emitter, namely:
  • Enable the shift emitter and set a type of particles to chain for both particle systems
  • Change parameters of the material applied to each particle system so that were different from each other
Continuous flows of particles
Last update: 2020-07-31
