mesh_02
This article describes the data/samples/objects/mesh_02.cpp sample.
The mesh_02 sample demonstrates how to deform a static mesh as a dynamic mesh, namely:
- Load the static mesh from a given file and copy it to the dynamic mesh by using the setMesh() function
- Deform vertices of the dynamic mesh
- Add the deformed dynamic mesh as the static mesh to the editor
49 dynamic ObjectMeshes
The static mesh used in this sample is stored in the samples/objects/meshes/mesh_02.mesh file.
- Article on Static Mesh
- Article on Dynamic Mesh
- Functions of the ObjectMeshStatic class
- Functions of the ObjectMeshDynamic class
