Sandworm (Experimental)
Unigine::ObjectMeshSkinned Class
Inherits: Object
This class is used to create or modify skinned meshes.
Creating and Playing Animation#
To add the animation to the ObjectMeshSkinned and play it, do the following:
  1. Set the number of animation layers with the setNumLayers() method. There is only one layer by default.
  2. Enable the layer and set the animation weight for blending by calling the setLayer() function.
  3. Add the animation .anim file by using addAnimation() or setAnimation() functions.
    When you import your model with animations from an FBX container, the following path to your *.anim files should be used: <path_to_your_fbx_file>/<file.fbx>/<your_anim_file.anim>
    For example: object->addAnimation("models/soldier/soldier.fbx/run.anim");
    The recommended approach is to use the Component System and provide the guid of the .anim file.
    UGUID guid = FileSystem::getGUID(anim_asset.getRaw());
    int animation_1 = skinned_mesh->addAnimation(mesh,guid.getFileSystemString(), "run");
  4. Play the added animation by calling the setFrame() function for each animation layer.
Blending is performed between all layers. The contribution of each layer depends on its weight. Also, you can optionally define single bone transformations by hand, if needed, using either setBoneTransform() or setBoneTransformWithChildren().
Usage Example
The following example shows how to blend 2 different animations assigned to a mesh. In this example we use the mesh and animations from UNIGINE samples located in <UnigineSDK>/data/samples/animation/meshes and <UnigineSDK>/data/samples/animation/animations folders, respectively. Animations are added by using the addAnimation() function.
Below you'll find an example of using the Component System to access animation assets.
  1. Create a component for controlling loading of animations and generate a property for it.
  2. Assign its property to the target controller node.
  3. Assign desired animation assets to the parameters of the property by using the Editor.
    Assigning animation assets to property parameters via the Editor
  4. Implement logic of creating a skinned mesh with the specified animations. The complete source code:
    SkinnedMeshController.h
    #pragma once
    #include <UnigineObjects.h>
    #include <UnigineStreams.h>
    #include <UnigineLog.h>
    #include <UnigineEditor.h>
    #include <UnigineGame.h>
    class SkinnedMeshController : public ComponentBase
    	COMPONENT(SkinnedMeshController, ComponentBase);
    	COMPONENT_INIT(init);
    	COMPONENT_UPDATE(update);
    	COMPONENT_SHUTDOWN(shutdown);
    	PROP_NAME("skinned_controller_property");
    	// property parameters for mesh and animation assets
    	PROP_PARAM(File, mesh_asset);
    	PROP_PARAM(File, anim_asset_1);
    	PROP_PARAM(File, anim_asset_2);
    protected:
    	void init();
    	void update();
    	void shutdown();
    // the pointer to the skinned mesh object
    	ObjectMeshSkinnedPtr skinned_mesh;
    SkinnedMeshController.cpp
    #include "SkinnedMeshController.h"
    // register the component
    REGISTER_COMPONENT(SkinnedMeshController);
    int SkinnedMeshController::init() {
    	// get the guid of the mesh asset
    	const char *mesh_path = FileSystem::getGUID(mesh_asset.getRaw()).getFileSystemString();
    	// create the new ObjectMeshSkinned mesh based on an existing mesh
    	skinned_mesh = ObjectMeshSkinned::create(mesh_path);
    	skinned_mesh->setMaterial("mesh_base", "*");
    	// set the number of animation layers
    	skinned_mesh->setNumLayers(2);
    	// get the guids of the animation assets
    	const char *path_1 = FileSystem::getGUID(anim_asset_1.getRaw()).getFileSystemString();
    	const char *path_2 = FileSystem::getGUID(anim_asset_2.getRaw()).getFileSystemString();
    	// load animations from the files
    	int animation_1 = skinned_mesh->addAnimation(path_1);
    	int animation_2 = skinned_mesh->addAnimation(path_2);
    	// enable each layer and set an animation weight
    	skinned_mesh->setLayer(0, 1, 0.7);
    	skinned_mesh->setLayer(1, 1, 0.3);
    	// set animations to layers
    	skinned_mesh->setAnimation(0, animation_1);
    	skinned_mesh->setAnimation(1, animation_2);
    int SkinnedMeshController::update() {
    	// play each animation
    	skinned_mesh->setFrame(0, Game::getTime() * 25.0f);
    	skinned_mesh->setFrame(1, Game::getTime() * 25.0f);
    int SkinnedMeshController::shutdown() {
Updating Bone Transformations#
Some of the methods require to update the animation data before the renderer makes its update and actually draws the skinned mesh. Such update allows to get the correct result of blending between the frames and layers.
The execution sequence of updating bone transformations is the following:
  1. Call the method, which sets the update flag. This flag shows that the instance should be updated.
  2. Update the bone transformations by calling proper functions. These functions check the flag and if the flag is set, they calculate the transformations and set the flag to the default value.
  3. During the rendering, the engine performs animations and transformations which were calculated on the previous step or recalculates them, if the update flag has been set. If calculations have been performed, the flag is set to the default value.
If you try to update bone transformations before you set the flag to update, functions will not calculate new transformations and the engine doesn't perform them.
When you change the transformation of the bone, you should notify all skinned meshes which use these bone about these transformations to update the mesh. When you change transformations of a bone, skinned mesh instances get the flag to update. When you use the setFrame() function, you set necessary transformations for the specified skinned mesh.
Instancing#
Surfaces of identical skinned meshes which have the same materials assigned to them and the same number of bones attached to their vertices are automatically instanced and drawn in one draw call. The instancing flag is enabled by default (see corresponding console commands).
The data buffers for instanced objects that store bones transformations are limited in size; therefore, if skinned meshes have many bones, only a few meshes can populate the instance data buffer to be drawn in one draw call.
The higher the number of bones and the more bones are attached to one surface, the less robust instancing will be.
  • Mesh class
  • Article on Mesh File Formats
  • Samples located in the <UnigineSDK>/data/samples/animation folder
Enums
BONE_SPACE#
Defines which transformation of the bone is to be overridden by the bind node's transformation.
NameDescription
BONE_SPACE_WORLD = 0World coordinates.
BONE_SPACE_OBJECT = 1Coordinates relative to the skinned mesh object.
BONE_SPACE_LOCAL = 2Coordinates relative to the parent bone.
NODE_SPACE#
Defines the type of transformation of the bind node to be used to override the transformation of the specified bone.
NameDescription
NODE_SPACE_WORLD = 0World transformation of the node.
NODE_SPACE_LOCAL = 1Local transformation of the node.
BIND_MODE#
Type of blending of bind node's and bone's transformations.
NameDescription
BIND_MODE_OVERRIDE = 0Replace bone's transformation with the transformation of the bind node.
BIND_MODE_ADDITIVE = 1Bind node's transformation is added to the current transformation of the bone.
Members
static ObjectMeshSkinnedPtr create ( const Ptr<Mesh> & mesh ) #
ObjectMeshSkinned constructor.
Arguments
  • const Ptr<Mesh> & mesh - Pointer to Mesh.
static ObjectMeshSkinnedPtr create ( const char * path, bool unique = false ) #
Arguments
  • const char * path - Path to the skinned mesh file.
  • bool unique - When you create several objects out of a single .mesh file, the instance of the mesh geometry is created. If you then change the source geometry, its instances will be changed as well. To avoid this, set the unique flag to true (1), so a copy of the mesh geometry will be created and changes won't be applied.
int setAnimation ( int layer, int animation ) #
Sets the animation identifier for the given animation layer.
Arguments
  • int layer - Layer number.
  • int animation - Animation identifier.
int setAnimation ( int layer, const char * path ) #
Sets the path to animation for the given animation layer.
Arguments
  • const char * path - Path to animation file.
int getAnimation ( int layer ) const#
Returns the animation identifier from the given animation layer.
Arguments
Return value
int getAnimationID ( int num ) const#
Returns the identifier of the animation at the specified position.
Arguments
  • int num - Animation number.
Return value
const char * getAnimationPath ( int animation ) const#
Returns the path to a file containing the specified animation.
Arguments
Return value
Path to a file containing the specified animation.
void setAnimName ( const char * name ) #
Sets a new path to the animation. Does not update animation immediately using the new path, unlike the setAnimNameForce() method.
Arguments
  • const char * name - Path to the animation.
void setAnimNameForce ( const char * name ) #
Sets the new path to the animation and forces setting this animation for the first animation layer.
Arguments
  • const char * name - Path to the animation file.
const char * getAnimName ( ) const#
Returns the path to the current animation.
Return value
Path to animation.
Math::mat4 getBoneBindTransform ( int bone ) const#
Returns the bind pose bone transformation matrix. Bone transformations are relative.
Arguments
  • int bone - Bone number.
Return value
Bind pose bone transformation matrix.
int getBoneChild ( int bone, int child ) const#
Returns the number of a child of a given bone.
Arguments
  • int child - Child number.
Return value
Number of the child in the collection of all bones.
void setBoneTransformWithChildren ( int bone, const Math::mat4 & transform ) #
Sets transformation for the bone and all of its children (without considering node transformations).
Bones can be scaled only uniformly.
Arguments
  • const Math::mat4 & transform - Transformation matrix.
const char * getBoneName ( int bone ) const#
Returns the name of the given bone.
Arguments
Return value
Bone name.
int getBoneParent ( int bone ) const#
Returns the number of the parent bone for a given one.
Arguments
  • int bone - Number of the bone, for which the parent will be returned.
Return value
Parent bone number, if the parent exists; otherwise, -1.
void setBoneTransform ( int bone, const Math::mat4 & transform ) #
Sets a transformation matrix for a given bone (without considering node transformations).
Arguments
Math::mat4 getBoneTransform ( int bone ) const#
Returns a transformation matrix of a given bone relatively to the parent object (not considering transformations of the node itself).
Arguments
Return value
void setBoneTransforms ( const int * bones, const Math::mat4 * transforms, int num_bones ) #
Sets a transformation matrix for given bones.
Arguments
  • const int * bones - Bone numbers.
  • const Math::mat4 * transforms - Transformation matrices.
  • int num_bones - Number of bones.
void setCIndex ( int num, int index, int surface ) #
Sets the new coordinate index for the given vertex of the given surface.
Arguments
  • int num - Vertex number in the range from 0 to the total number of coordinate indices for the given surface.
    To get the total number of coordinate indices for the given surface, use the getNumCIndices() method.
  • int index - Coordinate index to be set in the range from 0 to the total number of coordinate vertices for the given surface.
    To get the total number of coordinate vertices for the given surface, use the getNumCVertex() method.
  • int surface - Mesh surface number.
int getCIndex ( int num, int surface ) const#
Returns the coordinate index for the given vertex of the given surface.
Arguments
Return value
Coordinate index.
void setColor ( int num, const Math::vec4 & color, int surface ) #
Sets the color for the given triangle vertex of the given surface.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of vertex color entries of the given surface.
    To get the total number of vertex color entries for the surface, call the getNumColors() method.
  • const Math::vec4 & color - Vertex color to be set.
Math::vec4 getColor ( int num, int surface ) const#
Returns the color of the given triangle vertex of the given surface.
Arguments
Return value
Vertex color.
void setControlled ( bool controlled ) #
Sets a value indicating if the animation should be controlled by a parent ObjectMeshSkinned (useful for attaching clothes to a character body).
Arguments
  • bool controlled - Controlled flag: true if the animation is controlled by a parent ObjectMeshSkinned; otherwise - false.
bool isControlled ( ) const#
Returns a value indicating if the animation is controlled by a parent ObjectMeshSkinned.
Return value
true if the animation is controlled by a parent ObjectMeshSkinned; otherwise, false.
float setFrame ( int layer, float frame, int from = -1, int to = -1 ) #
Sets a frame for the given animation layer.
Arguments
  • int layer - Animation layer number.
  • float frame - Frame number in the "from-to" interval. If the float argument is passed, animation is interpolated between nearby frames. 0 means the from frame. For larger values, a residue of a modulo (from-to) is calculated. If a negative value is provided, interpolation will be done from the current frame to the from frame.
  • int from - Start frame. -1 means the first frame of the animation.
  • int to - End frame. -1 means the last frame of the animation.
Return value
The number of the frame.
float getFrame ( int layer ) const#
Returns the frame number passed as the time argument on the last setFrame() call.
Arguments
Return value
Frame number.
int getFrameFrom ( int layer ) const#
Returns the start frame passed as the from argument on the last setFrame() call.
Arguments
Return value
Start frame.
int getFrameTo ( int layer ) const#
Returns the end frame passed as the to argument on the last setFrame() call.
Arguments
Return value
End frame.
Math::mat4 getBoneBindITransform ( int bone ) const#
Returns the inverse bone transformation matrix of the bind pose in the world-space.
To get the bind pose transformation matrix in the world-space, use the inverse(getBoneITransform()).
Arguments
Return value
Inverse bind pose transformation matrix.
Math::mat4 getBoneITransform ( int bone ) const#
Returns an inverse transformation matrix for a given bone relatively to the parent object.
Arguments
Return value
Inverse transformation matrix.
void setLayer ( int layer, bool enabled, float weight ) #
Enables or disables the given animation layer and sets the value of the weight parameter.
Arguments
  • bool enabled - Enable flag. true to enable the layer, false to disable it.
  • float weight - Animation layer weight.
void setBoneLayerTransform ( int layer, int bone, const Math::mat4 & transform ) #
Sets a transformation matrix for a given bone. The difference from the setBoneTransform() function is that this method takes into account only the transformation in the specified animation layer (no blending is performed).
The bone can be scaled only uniformly.
Arguments
  • const Math::mat4 & transform - Bone transformation matrix.
Math::mat4 getBoneLayerTransform ( int layer, int bone ) const#
Returns a transformation matrix of a given bone relatively to the parent object.
The difference from getBoneTransform() is that this method takes into account only the transformation in the animation layer (no blending is done).
Arguments
Return value
bool isBoneLayerTransform ( int layer, int bone ) const#
Returns a value indicating if the bone transformation is applied only to the animation layer (no blending is performed).
Arguments
Return value
true if the bone transformation is applied only to the animation layer; otherwise, false.
void setBoneLayerTransformEnabled ( int layer, int bone, bool enabled ) #
Enables or disables a layer transformation for a given bone.
Arguments
  • bool enabled - Enabled flag: true to enable layer transformation, false to disable it.
void setLayerEnabled ( int layer, bool enabled ) #
Enables or disables a given animation layer.
Arguments
  • bool enabled - true to enable the animation layer, false to disable it.
bool isLayerEnabled ( int layer ) const#
Returns a value indicating if a given animation layer is enabled.
Arguments
Return value
true if the layer is disabled; otherwise, false.
void setLayerWeight ( int layer, float weight ) #
Sets a weight for the animation layer.
Arguments
float getLayerWeight ( int layer ) const#
Returns the weight of the animation layer.
Arguments
Return value
Weight of the animation layer.
void setLoop ( int loop ) #
Sets a value indicating if the animation should be looped.
Arguments
  • int loop - 1 is to play the animation in a loop, 0 is to play it only once.
int getLoop ( ) const#
Returns a value indicating if the animation is looped. 1 if the animation is looped; otherwise - 0.
Return value
The loop flag.
int setMesh ( const Ptr<Mesh> & mesh ) #
Copies the source mesh into the current mesh.
// create ObjectMeshSkinned instances
ObjectMeshSkinnedPtr skinnedMesh = ObjectMeshSkinned::create("soldier.mesh");
ObjectMeshSkinnedPtr skinnedMesh_2 = ObjectMeshSkinned::create("doll.mesh");
// create a Mesh instance
MeshPtr firstMesh = Mesh::create();
// get the mesh of the ObjectMeshSkinned and copy it to the Mesh class instance
skinnedMesh->getMesh(firstMesh);
// put the firstMesh mesh to the skinnedMesh_2 instance
skinnedMesh_2->setMesh(firstMesh);
Arguments
  • const Ptr<Mesh> & mesh - The source mesh to be copied.
Return value
1 if the mesh is copied successfully; otherwise, 0.
int getMesh ( const Ptr<Mesh> & mesh ) const#
Copies the current mesh into the source mesh.
// a skinned mesh from which geometry will be obtained
ObjectMeshSkinnedPtr skinnedMesh = ObjectMeshSkinned::create("skinned.mesh");
// create a new mesh
// copy geometry to the created mesh
if (skinnedMesh->getMesh(mesh)) {
	// do something with the obtained mesh
else {
	Log::error("Failed to copy a mesh\n");
Arguments
  • const Ptr<Mesh> & mesh - Source mesh.
Return value
void setMeshName ( const char * name ) #
Sets the path to the mesh. Does not update mesh immediately using the new path, unlike the setMeshNameForce() method
Arguments
  • const char * name - Path to the mesh.
void setMeshNameForce ( const char * path ) #
Sets the new path to the mesh and forces mesh creation using the new path. The new mesh is created from the specified path immediately with the unique flag set to 0.
Arguments
  • const char * path - Path to the mesh file.
const char * getMeshName ( ) const#
Returns the path to the mesh.
Return value
Path to the mesh.
int getMeshSurface ( const Ptr<Mesh> & mesh, int surface, int target = -1 ) const#
Copies the specified mesh surface to the destination mesh.
Arguments
  • const Ptr<Mesh> & mesh - Destination Mesh to copy the surface to.
  • int surface - Number of the mesh surface to be copied.
  • int target - Number of the surface morph target to be copied. The default value is -1 (all morph targets).
Return value
Number of the new added mesh surface.
Math::vec3 getNormal ( int num, int surface, int target = 0 ) const#
Returns the normal for the given triangle vertex of the given surface target.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of vertex tangent entries of the given surface target.
    Vertex normals are calculated using vertex tangents. To get the total number of vertex tangent entries for the surface target, call the getNumTangents() method.
  • int target - Surface target number. The default value is 0.
Return value
Vertex normal.
int getNumAnimationBones ( int animation ) const#
Returns the number of animation bones.
Arguments
  • int animation - Animation number.
Return value
Number of animation bones.
int getNumAnimationFrames ( int animation ) const#
Returns the number of animation frames.
Arguments
Return value
Number of animation frames.
int getNumAnimations ( ) const#
Returns the total number of all loaded animations.
Return value
Number of loaded animations.
int getNumBoneChildren ( int bone ) const#
Returns the number of children for the specified bone.
Arguments
Return value
Number of child bones.
int getNumBones ( ) const#
Returns the number of all bones taking part in animation.
Return value
Number of bones.
int getNumCIndices ( int surface ) const#
Returns the number of coordinate indices for the given mesh surface.
Arguments
Return value
Number of coordinate indices.
int getNumColors ( int surface ) const#
Returns the total number of vertex color entries for the given surface.
Colors are specified for triangle vertices.
Arguments
  • int surface - Surface number.
Return value
Number of vertex color entries.
int getNumFrames ( int layer ) const#
Returns the number of animation frames for a given layer.
Arguments
Return value
void setNumLayers ( int layers ) #
Sets the number of animation layers for blending. For example, when two layers are blended, bone transformations in between the layers are interpolated, and vertex positions can be calculated using the interpolated results. For more details, see the article on Skinned Mesh.
Arguments
  • int layers - Number of animation layers (must be greater than 0).
int getNumLayers ( ) const#
Returns the number of animation layers set for blending. For more details, see the article on Skinned Mesh.
Return value
Number of animation layers.
int getNumSurfaceTargets ( int surface ) const#
Returns the number of surface morph targets for the given mesh surface.
Arguments
Return value
Number of surface morph targets.
int getNumTangents ( int surface ) const#
Returns the number of vertex tangent entries of the given mesh surface.
Tangents are specified for triangle vertices.
Arguments
Return value
Number of surface tangent vectors.
void setNumTargets ( int num, int surface ) #
Sets the number of animation morph targets for the given mesh surface.
Arguments
  • int num - Number of animation morph targets.
int getNumTargets ( int surface ) const#
Returns the total number of morph targets of the given mesh surface.
Arguments
Return value
void setNumTexCoords0 ( int num, int surface ) #
Sets the number of the first UV map texture coordinates for the given mesh surface.
First UV map texture coordinates are specified for triangle vertices.
Arguments
  • int num - Number of the first UV map texture coordinates to be set.
int getNumTexCoords0 ( int surface ) const#
Returns the number of the first UV map texture coordinates for the given mesh surface.
Arguments
Return value
Number of the first UV map texture coordinates.
void setNumTexCoords1 ( int num, int surface ) #
Sets the number of the second UV map texture coordinates for the given mesh surface.
Second UV map texture coordinates are specified for triangle vertices.
Arguments
  • int num - Number of the second UV map texture coordinates to be set.
int getNumTexCoords1 ( int surface ) const#
Returns the number of the second UV map texture coordinates for the given mesh surface.
Arguments
Return value
Number of the second UV map texture coordinates.
int getNumTIndices ( int surface ) const#
Returns the number of triangle indices for the given mesh surface.
Arguments
Return value
Number of triangle indices.
int getNumVertex ( int surface ) const#
Returns the number of coordinate vertices for the given mesh surface.
Arguments
Return value
Number of the surface vertices.
bool isFlushed ( ) const#
Returns a value indicating if vertex data of the mesh was flushed (create/upload operation) to video memory.
Return value
true if vertex data of the mesh was flushed (create/upload operation) to video memory; otherwise, false.
bool isPlaying ( ) const#
Returns playback status.
Return value
true if animation is playing; otherwise, false.
void setQuaternion ( bool quaternion ) #
Enables or disables the dual-quaternion skinning mode. The dual-quaternion model is an accurate, computationally efficient, robust, and flexible method of representing rigid transforms and it is used in skeletal animation. See a Wikipedia article on dual quaternions and a beginners guide to dual-quaternions for more information.
Arguments
  • bool quaternion - true to enable dual-quaternion skinning mode, false to disable it.
bool isQuaternion ( ) const#
Returns the value indicating if the dual-quaternion skinning mode is used. The dual-quaternion model is an accurate, computationally efficient, robust, and flexible method of representing rigid transforms and it is used in skeletal animation. See a Wikipedia article on dual quaternions and a beginners guide to dual-quaternions for more information.
Return value
true if dual-quaternion skinning mode is used; otherwise, false.
Math::vec3 getSkinnedNormal ( int num, int index, int surface ) const#
Returns the skinned normal for the given triangle vertex.
A skinned normal is a recalculated normal for bones and morph targets used in skinning.
Arguments
  • int index - Coordinate index of the vertex.
    if -1 is passed, the coordinate index will be obtained for the first vertex having its triangle index equal to the specified triangle vertex number.
Return value
Skinned normal.
Math::quat getSkinnedTangent ( int num, int index, int surface ) const#
Returns the skinned tangent vector for the given triangle vertex.
A skinned tangent vector is a recalculated tangent vector for bones and morph targets used in skinning.
Arguments
Return value
Skinned tangent.
Math::vec3 getSkinnedVertex ( int num, int surface ) const#
Returns skinned coordinates of the given coordinate vertex.
A skinned vertex is a recalculated vertex for bones and morph targets used in skinning.
Arguments
  • int num - Coordinate vertex number in the range from 0 to the total number of coordinate vertices for the given surface.
    To get the total number of coordinate vertices for the given surface, use the getNumVertex() method.
Return value
Vertex coordinates.
void setSpeed ( float speed ) #
Updates a multiplier value for the animation playback time.
Arguments
  • float speed - Playback speed multiplier value.
float getSpeed ( ) const#
Returns a multiplier for animation playback time.
Return value
bool isStopped ( ) const#
Returns stop status.
Return value
true if animation is stopped; otherwise, false.
const char * getSurfaceTargetName ( int surface, int target ) const#
Returns the name of the morph target for the given mesh surface.
Arguments
  • int target - Morph target number.
Return value
Morph target name.
void setSurfaceTransform ( const Math::mat4 & transform, int surface, int target = -1 ) #
Transforms the given mesh surface target.
Arguments
  • int target - Morph target number. The default value is -1 (the transformation will be applied to all morph targets).
void setTangent ( int num, const Math::quat & tangent, int surface, int target = 0 ) #
Sets the new tangent for the given triangle vertex of the given surface target.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of vertex tangent entries of the given surface.
    To get the total number of vertex tangent entries for the surface, call the getNumTangents() method.
  • const Math::quat & tangent - Tangent to be set.
Math::quat getTangent ( int num, int surface, int target = 0 ) const#
Returns the tangent for the given triangle vertex of the given surface target.
Arguments
Return value
Vertex tangent.
void setTarget ( int target, bool enabled, int index, float weight, int surface ) #
Enables or disables a given morph target and sets all its parameters.
Arguments
  • bool enabled - Enable flag: true to enable the morph target; false to disable it.
  • int index - Target index.
  • float weight - Target weight.
void setTargetEnabled ( int target, bool enabled, int surface ) #
Enables or disables a given morph target.
Arguments
  • bool enabled - true to enable the morph target, false to disable it.
int isTargetEnabled ( int target, int surface ) const#
Returns a value indicating if the given morph target of the given surface is enabled.
Arguments
Return value
1 if the given morph target of the given surface is enabled; otherwise, 0.
void setTargetIndex ( int target, int index, int surface ) #
Sets an index for the given morph target.
Arguments
  • int index - Morph target index.
int getTargetIndex ( int target, int surface ) const#
Returns the index of the morph target. Returns the index of the given morph target.
Arguments
Return value
Index of the given morph target.
void setTargetWeight ( int target, float weight, int surface ) #
Sets a weight for the given animation target.
Arguments
  • float weight - Morph target weight.
float getTargetWeight ( int target, int surface ) const#
Returns the weight of the given morph target.
Arguments
Return value
void setTexCoord0 ( int num, const Math::vec2 & texcoord, int surface ) #
Sets first UV map texture coordinates for the given triangle vertex of the given surface.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of first UV map texture coordinate entries of the given surface.
    To get the total number of first UV map texture coordinate entries for the surface, call the getNumTexCoords0() method.
  • const Math::vec2 & texcoord - First UV map texture coordinates to be set.
Math::vec2 getTexCoord0 ( int num, int surface ) const#
Returns first UV map texture coordinates for the given triangle vertex of the given surface.
Arguments
Return value
First UV map texture coordinates.
void setTexCoord1 ( int num, const Math::vec2 & texcoord, int surface ) #
Sets second UV map texture coordinates for the given triangle vertex of the given surface.
Arguments
  • int num - Triangle vertex number in the range from 0 to the total number of second UV map texture coordinate entries of the given surface.
    To get the total number of second UV map texture coordinate entries for the surface, call the getNumTexCoords1() method.
  • const Math::vec2 & texcoord - Second UV map texture coordinates to be set.
Math::vec2 getTexCoord1 ( int num, int surface ) const#
Returns second UV map texture coordinates for the given triangle vertex of the given surface.
Arguments
Return value
Second UV map texture coordinates.
void setTime ( float time ) #
Sets the animation time, in animation frames. The time count starts from the zero frame. If the time is set to be between frames, animation is blended. If the time is set outside the animation frame range, the animation is looped.
The setTime() function corresponds to The Play and Stop options in the editor. In all other cases use setFrame() to set the animation.
Arguments
  • float time - Animation time.
float getTime ( ) const#
Returns the current animation time, in animation frames. The time count starts from the zero frame.
Return value
Animation time.
void setTIndex ( int num, int index, int surface ) #
Sets the new triangle index for the given vertex of the given surface.
Arguments
  • int num - Vertex number in the range from 0 to the total number of triangle indices for the given surface.
    To get the total number of triangle indices, use the getNumTIndices() method.
  • int index - Triangle index to be set in the range from 0 to the total number of triangle vertices for the given surface.
    To get the total number of triangle vertices for the given surface, use the getNumTVertex() method.
int getTIndex ( int num, int surface ) const#
Returns the triangle index for the given surface by using the index number.
Arguments
    To get the total number of triangle indices for the given surface, use the getNumTIndices() method.
Return value
Triangle index.
void setVertex ( int num, const Math::vec3 & vertex, int surface, int target = 0 ) #
Sets the coordinates of the given coordinate vertex of the given surface target.
Arguments
  • const Math::vec3 & vertex - Vertex coordinates to be set.
Math::vec3 getVertex ( int num, int surface, int target = 0 ) const#
Returns coordinates of the given coordinate vertex of the given surface target.
Arguments
Return value
Vertex coordinates.
void setBoneWorldTransformWithChildren ( int bone, const Math::Mat4 & transform ) #
Sets the transformation for the given bone and all of its children in the world coordinate space (considering node transformations).
Arguments
  • const Math::Mat4 & transform - Transformation matrix in the world space.
void setBoneWorldTransform ( int bone, const Math::Mat4 & transform ) #
Sets the transformation for the given bone in the world coordinate space.
Arguments
Math::Mat4 getBoneWorldTransform ( int bone ) const#
Returns the current transformation matrix applied to the bone in the world coordinate space (considering node transformations).
Arguments
Return value
int addAnimation ( const Ptr<Mesh> & mesh, const char * path = 0 ) #
Loads an additional animation from an external file.
UGUID guid;
guid.generate();
Arguments
  • const Ptr<Mesh> & mesh - Mesh containing the animation to be added.
  • const char * path - The parameter is a virtual unique path defining the animation. After loading the animation clip, its internal representation will be identified by the path when using findAnimation, setAnimation, etc. The default 0 value implies that the names of the animation clips will be used.
    As the given mesh isn't associated with a file and, therefore, doesn't have path data, the path must be represented by an arbitrary unique string. You can generate a new string and use it as the virtual path for the animation.
Return value
int addAnimation ( const char * path ) #
Loads the additional animation from an external file.
Arguments
  • const char * path - Path to the animation file. The path can be represented by either a path to the file or its GUID, which is the recommended approach. After loading the animation, its internal representation is identified by the path when using findAnimation, setAnimation, etc.
Return value
int addEmptySurface ( const char * name, int num_vertex, int num_indices ) #
Appends a new empty surface to the current mesh.
Arguments
  • const char * name - Name of the new surface.
  • int num_vertex - Number of vertices of the new surface.
  • int num_indices - Number of indices of the new surface.
Return value
Number of the new added surface.
int addLayer ( ) #
Appends a new animation layer to the current mesh.
Return value
Number of the new added animation layer.
int addMeshSurface ( const char * name, const Ptr<ObjectMeshSkinned> & mesh, int surface, int target = -1 ) #
Appends a new mesh surface to the current mesh.
Arguments
  • const char * name - Name of the new surface of the current mesh.
  • const Ptr<ObjectMeshSkinned> & mesh - Mesh pointer to copy a surface from.
  • int surface - Number of mesh surface to copy.
  • int target - Number of mesh target to copy. The default value is -1 (all morph targets will be copied).
Return value
Number of the added mesh surface.
int addMeshSurface ( int dest_surface, const Ptr<ObjectMeshSkinned> & mesh, int surface, int target = -1 ) #
Merges the specified surface from the source ObjectMeshSkinned with the specified destination surface of the mesh.
Arguments
  • int dest_surface - Number of the destination surface, with which a surface from the source ObjectMeshSkinned is to be merged.
  • const Ptr<ObjectMeshSkinned> & mesh - Source ObjectMeshSkinned to copy a surface from.
  • int surface - Number of the source mesh surface to copy.
  • int target - Number of mesh target to merge. The default value is -1 (all morph targets will be merged).
Return value
Number of the destination mesh surface.
int addMeshSurface ( const char * name, const Ptr<Mesh> & mesh, int surface, int target = -1 ) #
Appends a new mesh surface to the current mesh by copying the specified surface from the source mesh.
Arguments
  • const Ptr<Mesh> & mesh - Source mesh to copy a surface from.
Return value
int addSurfaceTarget ( int surface, const char * name = 0 ) #
Appends a new morph target to the given mesh surface.
Arguments
  • int surface - Number of the surface, to which the morph target will be appended.
  • const char * name - Name of the new morph target.
Return value
Number of the new added morph target.
int addSurfaceTarget ( int dest_surface, const Ptr<ObjectMeshSkinned> & src_mesh, int src_surface, int src_target = -1 ) #
Appends a new morph target to the given mesh surface by copying it from the specified surface of the source ObjectMeshSkinned.
Arguments
  • int dest_surface - Number of the surface, to which the morph target will be appended.
  • const Ptr<ObjectMeshSkinned> & src_mesh - Source ObjectMeshSkinned to copy the morph target from.
  • int src_surface - Number of the surface of the source ObjectMeshSkinned to copy the morph target from.
  • int src_target - Number of the morph target to copy. The default value is -1 (all morph targets will be copied).
Return value
int addTarget ( int surface ) #
Appends a new empty morph target to the given mesh surface.
Arguments
Return value
number of the new added morph target.
void clearLayer ( int layer ) #
Clears the given animation layer.
Arguments
void copyLayer ( int dest, int src ) #
Copies source layer bones transformations to the destination layer. The copying conditions are the following:
  • If the destination layer has more bones than the source one, it will keep its former transformations.
  • If the source layer has more bones than destination one, those bones will be added to the destination layer.
Arguments
  • int dest - Number of the destination layer in the range from 0 to the total number of animation layers.
    To get the total number of animation layers, use the getNumLayers() method.
  • int src - Number of the source layer in range from 0 to the total number of animation layers.
int createMesh ( const char * path, bool unique = 0 ) #
Creates a skinned mesh.
Arguments
  • bool unique - Dynamic flag:
    • false (0) - If the mesh vertices are changed in run-time, meshes loaded from the same file will be also changed.
    • true (1) - If the mesh vertices are changed in run-time, meshes loaded from the same file won't be changed
Return value
1 if the mesh is created successfully; otherwise - 0.
int findAnimation ( const char * path ) const#
Searches for an animation using the given path.
Arguments
    Use the path specified on animation loading.
Return value
Animation number, if found; otherwise, -1.
int findBone ( const char * name ) const#
Searches for a bone with a given name.
Arguments
  • const char * name - Bone name.
Return value
Bone number if found; otherwise, -1.
int findSurfaceTarget ( const char * name, int surface ) const#
Searches for a surface morph target with a given name.
Arguments
  • const char * name - Name of the morph target.
Return value
Number of the morph target, if exists; otherwise, -1.
void flushMesh ( ) #
Flushes mesh geometry to the video memory.
void importLayer ( int layer ) #
Copies the current bone state to the given animation layer.
Arguments
void inverseLayer ( int dest, int src ) #
Copies inverse transformations of bones from the source layer to the destination layer.
Destination layer is not cleared before transformations are written to it.
Arguments
  • int src - Number of the source layer in the range from 0 to the total number of animation layers.
void lerpLayer ( int dest, int layer0, int layer1, float weight ) #
Copies interpolated bone transformations from two source layers to a destination layer.
If there is no bone in one of the source layers, the bone transformation from another one will be copied to the destination layer without interpolation.
Arguments
  • int layer0 - Number of the first source layer in the range from 0 to the total number of animation layers.
  • int layer1 - Number of the second source layer in range from 0 to the total number of animation layers.
  • float weight - Interpolation weight.
int loadMesh ( const char * path ) #
Loads a new mesh instead of the current mesh from the .mesh file. This function doesn't change the mesh name.
Arguments
  • const char * path - The path to the .mesh file.
Return value
1 if the mesh is loaded successfully; otherwise, 0.
void mergeMeshSurface ( int dest_surface, const Ptr<ObjectMeshSkinned> & src_mesh, int src_surface ) #
Arguments
  • const Ptr<ObjectMeshSkinned> & src_mesh - Source ObjectMeshSkinned to copy a surface from.
  • int src_surface - Number of source mesh surface to merge.
void mulLayer ( int dest, int layer0, int layer1, float weight = 1.0f ) #
Copies multiplied bone transformations from two source layers to the destination layer.
Arguments
  • int layer1 - Number of the second source layer in the range from 0 to the total number of animation layers.
void play ( ) #
Continues playback of the animation, if it was paused, or starts playback if it was stopped.
void removeAnimation ( int animation ) #
Removes the given animation.
Arguments
void removeLayer ( int layer ) #
Removes an animation layer.
Arguments
  • int layer - Layer number in the range from 0 to the total number of animation layers.
void removeTarget ( int target, int surface ) #
Removes the given morph target.
Arguments
  • int target - Target number in the range from 0 to the total number of morph targets.
    To get the total number of morph targets for a given surface, use the getNumTargets() method.
int saveMesh ( const char * path ) #
Saves the mesh to .mesh or .anim format.
Arguments
  • const char * path - Path to the .mesh file.
Return value
1 if the mesh is saved successfully; otherwise, 0.
void stop ( ) #
Stops animation playback. This function saves the playback position so that playing of the animation can be resumed from the same point.
static int type ( ) #
Returns the type of the node.
Return value
Node type identifier.
void updateSurfaceBounds ( int surface = -1 ) #
Updates mesh surface bounds. This method is to be called to recalculate bounds after changing a mesh surface (e.g. modifying positions of coordinate vertices).
Arguments
  • int surface - Number of the surface to recalculate bound for. The default value is -1 (all surfaces).
void setFPSVisibleCamera ( int camera = -1 ) #
Sets the update rate value when the object is rendered to the viewport. The default value is set to infinity.
Arguments
  • int camera - Update rate value when the object is rendered.
int getFPSVisibleCamera ( ) const#
Returns the update rate value when the object is rendered to the viewport.
Return value
void setFPSVisibleShadow ( int shadow = 30 ) #
Sets the update rate value when only object shadows are rendered. The default value is set to 30 fps.
Arguments
  • int shadow - Update rate value when only object shadows are rendered.
int getFPSVisibleShadow ( ) const#
Returns the update rate value when only object shadows are rendered.
Return value
void setFPSInvisible ( int invisible = 0 ) #
Sets the update rate value when the object is not rendered at all. The default value is 0 fps.
Arguments
  • int invisible - Update rate value when the object is not rendered at all.
int getFPSInvisible ( ) const#
Returns the update rate value when the object is not rendered at all.
Return value
void setUpdateDistanceLimit ( float limit = 200 ) #
Sets the distance from the camera within which the object should be updated. The default value is 200 units.
Arguments
  • float limit - Distance from the camera within which the object should be updated.
float getUpdateDistanceLimit ( ) const#
Returns the distance from the camera within which the object should be updated.
Return value
void updateSkinned ( ) #
Forces update of all bone transformations.
Math::mat4 getBoneNotAdditionalBindLocalTransform ( int bone ) const#
Arguments
Math::mat4 getBoneNotAdditionalBindObjectTransform ( int bone ) const#
Arguments
Math::Mat4 getBoneNotAdditionalBindWorldTransform ( int bone ) const#
Arguments
void setBindNode ( int bone, const Ptr<Node> & node ) #
Sets a new node whose transformation is to be used to control the transformation of the bone with the specified number.
Arguments
  • int bone - Number of the bone to be controlled by the specified node, in the range from 0 to the total number of bones.
  • const Ptr<Node> & node - Node whose transformation is used to control the transformation of the bone.
void removeBindNode ( int bone ) #
Removes the assigned bind node from the bone with the specified number.
Arguments
Ptr<Node> getBindNode ( int bone ) const#
Returns the bind node currently assigned to the bone with the specified number.
Arguments
Return value
Node whose transformation is used to control the transformation of the bone if it is assigned; otherwise - nullptr.
void setBindNodeSpace ( int bone, ObjectMeshSkinned::NODE_SPACE space ) #
Sets a new value indicating which transformation of the bind node (World or Local) is to be used to override the transformation of the specified bone.
Arguments
ObjectMeshSkinned::NODE_SPACE getBindNodeSpace ( int bone ) const#
Returns the current value indicating which transformation of the bind node (World or Local) is to be used to override the transformation of the specified bone.
Arguments
Return value
Type of transformation of the bind node to be used to override the transformation of the specified bone, one of the NODE_SPACE* values.
void setBindBoneSpace ( int bone, ObjectMeshSkinned::BONE_SPACE space ) #
Sets a value indicating which transformation of the specified bone is to be overridden by the bind node's transformation.
Arguments
ObjectMeshSkinned::BONE_SPACE getBindBoneSpace ( int bone ) const#
Returns the current value indicating which transformation of the specified bone is to be overridden by the bind node's transformation.
Arguments
Return value
Current type of transformation of the specified bone overridden by the bind node's transformation, one of the BONE_SPACE* values.
void setBindMode ( int bone, ObjectMeshSkinned::BIND_MODE mode ) #
Sets a new type of blending of bind node's and bone's transformations.
Arguments
  • int bone - Number of the bone, in the range from 0 to the total number of bones.
  • ObjectMeshSkinned::BIND_MODE mode - New type of blending of bind node's and bone's transformations:
    • OVERRIDE - replace bone's transformation with the transformation of the node.
    • ADDITIVE - node's transformation is added to the current transformation of the bone.
ObjectMeshSkinned::BIND_MODE getBindMode ( int bone ) const#
Returns the current type of blending of bind node's and bone's transformations.
Arguments
Return value
Current type of blending of bind node's and bone's transformations:
void setBindNodeOffset ( int bone, const Math::Mat4 & offset ) #
Sets a new transformation matrix to be applied to the node's transformation before applying it to bone's transformation. This parameter serves for the purpose of additional correction of the node's transform for the bone's basis.
Arguments
  • const Math::Mat4 & offset - Transformation matrix applied to the node's transformation before applying it to bone's transformation.
Math::Mat4 getBindNodeOffset ( int bone ) const#
Returns the current transformation matrix which is applied to the node's transformation before applying it to bone's transformation. This parameter serves for the purpose of additional correction of the node's transform for the bone's basis.
Arguments
Return value
Transformation matrix currently applied to the node's transformation before applying it to bone's transformation.
void addVisualizeBone ( int bone ) #
Adds a bone with the specified number to the list of the bones for which the basis vectors are to be visualized.
Arguments
  • int bone - Number of the bone to be added to the visualizer, in the range from 0 to the total number of bones.
void removeVisualizeBone ( int bone ) #
Removes a bone with the specified number from the list of the bones for which the basis vectors are to be visualized.
Arguments
  • int bone - Number of the bone to be removed from the visualizer, in the range from 0 to the total number of bones.
void clearVisualizeBones ( ) #
Clears the list of the bones for which the basis vectors are to be visualized.
void setVisualizeAllBones ( bool bones ) #
Sets a value indicating if visualization for bones and their basis vectors is enabled. The visualizer can be used for debugging purposes showing positions of bones and their basis vectors for multiple meshes simultaneously.
Arguments
  • bool bones - true to enable visualization of bones and their basis vectors; false — to disable it.
bool isVisualizeAllBones ( ) const#
Returns a value indicating if visualization for bones and their basis vectors is enabled. The visualizer can be used for debugging purposes showing positions of bones and their basis vectors for multiple meshes simultaneously.
Return value
true if visualization for bones and their basis vectors is enabled; otherwise, false.
Last update: 2021-02-17
