Unigine::NodeReference Class
Header: #include <UnigineNodes.h>
Inherits: Node
A node reference is a node that refers to an external .node file on the disk, which is obtained by exporting a node from the world.
The world can contain several instances of node references referring to the same .node file.
The .node file usually contains a pre-fabricated node (or a hierarchy of nodes) with all the materials and properties that are required for its rendering. All changes that are made for the node reference via UnigineEditor are saved into this file.
When editing the node reference via the code, implement saving changes into the .node file.
The node reference should be used instead of the node if there a lot of identical objects repeated in the world: it will enable to avoid manual editing each object if you need to make the same changes in all of these objects.
A bounding box of the reference node is equal to the bounding box of its root node stored by the reference (child nodes are disregarded).
Unlike regular nodes, reference nodes are loaded into the world faster because of the internal cache usage.
An NodeReference instance is an owner of the node (or nodes) stored by the reference, so it is responsible for loading and deleting them.
Node Reference Transformations#
NodeReference transformation differs from transformation of the node (or nodes) stored by the reference. However, matrix hierarchy is used for a NodeReference. So, when moving the NodeReference, its root node stored by the reference will also move relatively to this NodeReference. At that, the local transformation matrix of the root reference node won't be changed.
  • Article on Nodes that lists the main differences between the regular nodes and reference nodes
  • Article on Node Reference
Creating a Node Reference#
To create a NodeReference, you should specify a path to the existing .node file. For example, you can export a node into a .node file and then create a NodeReference by using it:
#include <UnigineEditor.h>
#include <UnigineObjects.h>
#include <UnigineWorld.h>
int AppWorldLogic::init() {
	// create a mesh
	mesh->addBoxSurface("box_0", Math::vec3(1.0f));
	// create a dynamic mesh by using the mesh
	ObjectMeshDynamicPtr dynamic = ObjectMeshDynamic::create(mesh);
	// export the dynamic mesh into a .node file
	World::get()->saveNode("unigine_project/nodes/node_reference_0.node", dynamic->getNode());
	// create a node reference
	NodeReferencePtr nodeRef = NodeReference::create("unigine_project/nodes/node_reference_0.node");
	nodeRef->release();
	// add NodeReference to UnigineEditor
	Editor::get()->addNode(nodeRef->getNode());
Also you can cast a Node instance to the NodeReference. However, such type casting is possible only if the Node type is NODE_REFERENCE. For example:
// AppWorldLogic.h
#include <UnigineLogic.h>
#include <UnigineStreams.h>
#include <UnigineNode.h>
	AppWorldLogic();
	virtual ~AppWorldLogic();
	virtual int init();
	virtual int update();
	virtual int render();
	virtual int flush();
	virtual int shutdown();
	virtual int destroy();
	void nodeCast(Unigine::NodePtr node);
// AppWorldLogic.cpp
#include <UnigineConsole.h>
void AppWorldLogic::nodeCast(NodePtr node) {
	// check if the node is a NodeReference
	if (node->getType() == Node::NODE_REFERENCE)
		// cast the node to the NodeReference
		NodeReferencePtr nodeRef = NodeReference::cast(node);
		// set a name for the NodeReference
		nodeRef->setName("NodeReference_casted");
	// create a NodeReference from the file
	NodeReferencePtr nodeRef_0 = NodeReference::create("unigine_project/nodes/node_reference_0.node");
	// release script ownership
	nodeRef_0->release();
	// set a name
	nodeRef_0->setName("NodeReference_0");
	// add the NodeReference to UnigineEditor
	Editor::get()->addNode(nodeRef_0->getNode());
	// save changes into the .world file
	Console::get()->run("world_save");
	// get the added NodeReference as a Node
	NodePtr node = Editor::get()->getNodeByName("NodeReference_0");
	// cast the obtained Node to a NodeReference
	nodeCast(node);
In the result, the NodeReference_0 node will be converted to the NodeReference_casted node.
Editing a Node Reference#
Editing a NodeReference includes:
  • Changing the path to the referenced .node file.
  • Editing the node stored by the reference.
To access the node to which the NodeReference refers, use the getReference() method as follows:
	// create a NodeReference instance
	nodeRef->release();
	// set a name
	nodeRef->setName("NodeReference_0");
	// get a node stored by the reference and check if it is an ObjectMeshDynamic
	if (nodeRef->getReference()->getType() == Node::OBJECT_MESH_DYNAMIC) {
		// cast the referenced node to the ObjectMeshDynamic type
		ObjectMeshDynamicPtr dynamic = ObjectMeshDynamic::cast(nodeRef->getReference());
		// set a material
		dynamic->setMaterial("mesh_base", 0);
		// save changes on the referenced node into the .node file
		World::get()->saveNode(nodeRef->getNodeName(), dynamic->getNode());
In the result, the source .node file, to which the NodeReference refers, will be updated and the NodeReference_0 node will refer to the updated node with the material assigned.
NodeReference Class
Members
static NodeReferencePtr create ( const char * name ) #
Constructor. Creates a new object that references a node from a given file.
Arguments
  • const char * name - Path to a *.node file.
static Ptr<NodeReference> cast ( const Ptr<Node> & node ) #
Casts the Node instance to a NodeReference.
Arguments
  • const Ptr<Node> & node - Pointer to Node.
Return value
Pointer to NodeReference.
void setNodeName ( const char * name ) #
Sets a reference to a new *.node file.
// create an NodeReference instance
NodeReferencePtr nodeRef = NodeReference::create("unigine_project/nodes/reference_0.node");
// change a reference node
nodeRef->setNodeName("unigine_project/nodes/reference_1.node");
Arguments
const char * getNodeName ( ) #
Returns the path to the referenced *.node file.
// return the path to the reference node
Log::message("The referenced node is: %s\n",nodeRef->getNodeName());
Return value
Path to the referenced *.node file.
Ptr<Node> getReference ( ) #
Returns the node stored by the reference. The method should be used when you need to change the referenced node. If getReference() has returned a NodeDummy instance, it means that several nodes of the same hierarchy level has been converted into the NodeReference.
NodeReferencePtr nodeRef = NodeReference::create("unigine_project/nodes/single_nref.node");
NodePtr node = nodeRef->getReference();
// if the node is a NodeDummy
if (node->>getType() == Node::NODE_DUMMY){
	// print the type name of each child node of the root node stored by the reference
	for(int i = 0; i & node->getNumChildren(); i++) {
		Log::message("%d: %s\n",i,node->getChild(i)->getTypeName());
Return value
Node instance.
int canBeReference ( const char * name, const Ptr<Node> & node ) #
Returns a value indicating if the hierarchy of the given node does not contain a node reference with the given name.
Arguments
  • const char * name - Node reference name.
  • const Ptr<Node> & node - Node to check.
Return value
1 if the hierarchy of the given node does not contain a node reference with the given name; otherwise, 0.
Ptr<Node> detachReference ( ) #
Returns the node stored by the reference and releases this node of ownership so it is no longer owned by the NodeReference. The node becomes orphan and the NodeReference instance doesn't refer to the node. After being released the node should be appended to one of the scripts not to cause a memory leak.
To remove the node do the following:
// create a new NodeReference instance
// preform something
// get the node stored by the reference and release NodeReference ownership of the node
NodePtr node = nodeRef->detachReference();
// destroy the NodeReference pointer as the NodeReference doesn't refer to a node any more
nodeRef.destroy();
// add the obtained node to UnigineEditor
Editor::get()->addNode(node);
Return value
Root node of the internal hierarchy.
static int type ( ) #
Returns the type of the node.
Return value
NodeReference type identifier.
Last update: 2019-08-16
