Organizing Nodes
In Unigine, nodes are organized in a hierarchy that can be managed via the World Hierarchy window.
World Hierarchy Window
This window contains all nodes existing in the current world. Some of the nodes can be instances of the asset files: meshes, sounds, terrains, instanced nodes, nodes stored in the *.node files.
When you add a new node to the scene via the Menu Bar (the Create item) or by dragging it from the Asset Browser, this node is automatically added to the nodes hierarchy and displayed in the World Hierarchy window.
The World Hierarchy window allows filtering nodes by names, collapsing nodes hierarchy (i.e., showing only the parent nodes and hiding the child ones), rearranging, reparenting, cloning, renaming, deleting or grouping the nodes.
To open the World Hierarchy window, choose Windows -> Toggle World Hierarchy in the Menu Bar.
Renaming Nodes#
To rename a node, right-click it, choose Rename in the drop-down list and specify a new name.
Renaming a Node
A node can also be renamed via the Parameters window:
Renaming via Parameters Window
Renaming a node doesn't lead to renaming the asset it is linked to (if any).
Rearranging Nodes#
To move a node to a specific position in the hierarchy, drag it with the left mouse button pressed.
Moving a Node in Hierarchy
The position in the hierarchy, where the node will be placed, is highlighted with the white line:
Highlighted Position
Setting Up Nodes Inheritance#
Usually, nodes in the scene have hierarchical organization: each node (parent node) can have multiple children (child nodes). It allows you, for example, to change the transformation of several nodes only by transforming the parent node.
To collapse or expand the list of child nodes, click the arrow to the left of the parent node. You can also collapse all child nodes in the World Hierarchy window by clicking .
By default, a new node added to the scene is positioned at the root level of the nodes hierarchy. You can set up its inheritance in one of the ways described below.
Making a Parent Node#
To make one node a parent for the other node (or several nodes), select both, the parent and the desired child nodes, right-click the parent node and choose Make Parent in the drop-down list:
By using this option, you can perform reparenting for the hierarchy tree branch: select the target branch, right-click the desired parent node and choose Make Parent in the drop-down list. It produces the following:
  1. The new-made parent is always placed at the root level of the hierarchy.
  2. The child nodes positioned at the different hierarchy levels are placed at the same level.
Reparenting Nodes
Making a Child Node#
To add one node as a child to the other in the hierarchy, or reparent a node, drag it with the left mouse button pressed to the desired parent node.
Adding a Child Node
The parent node, to which the node will be added, is highlighted with the white frame:
Highlighted Parent Node
You can also move a node to a specific position alongside the child nodes of the desired parent: the node will be added as a child to this parent node.
Moving Node As a Child
Unparenting a Node#
To detach a node from its parent, right-click it and choose Unparent in the drop-down list:
The node is detached only from its direct parent and placed at the same level as the former parent.
Detaching a Node from Its Parent
To reset inheritance of a child node (i.e., detach it from all parents and place at the root level of the hierarchy), simply drag it to the corresponding position in the hierarchy.
Cloning a Node#
To clone a node, right-click it and choose Clone in the drop-down list:
Cloning Node
Also, you can select the node and press Ctrl+D to perform the same operation. The new node will be created at the same hierarchy level as the original one, and have the same transformation. If the original node has children, they will be cloned as well.
Another way to clone a node is to select it, press Shift and drag the node's arrow manipulator.
Deleting a Node#
To delete a node from the hierarchy, right-click it and choose Delete in the drop-down list:
Deleting Node
Also, you can select a node and press DELETE to perform the same operation.
If you delete a parent node, all its child nodes will be deleted as well.
Deleting a node doesn't lead to deleting the asset it is linked to (if any).
Filtering Nodes#
Filtering nodes simplifies managing nodes in a large world. You can select which node types to display in the World Hierarchy window: click and choose the required node types.
You can temporary show all objects by clicking Enable All. At that, the current filter settings will be preserved.
Filtering Nodes
Grouping Nodes#
Grouping nodes allows managing several nodes simultaneously. The grouped nodes can be transformed as a single node relative to a pivot point
When grouping nodes, a new dummy node is created, and all the selected nodes become its children. At that, the hierarchy of the grouped nodes persists.
To group the nodes, select them, right-click and choose Group in the drop-down list or press Ctrl+G:
Grouping Nodes
The grouped nodes can be selected and transformed as a single node:
Grouped Nodes
Last update: 2018-12-27
