World Trigger
A world trigger is a cuboid shaped object, which fires callbacks when any node (collider or not) gets inside or outside of it.
A World Trigger Affecting Meshes
  • WorldTrigger class to edit world triggers via UnigineScript
Creating a World Trigger
To create a world trigger, choose the Add World Trigger option in the list of nodes of Editor panel. In the creation dialog window, specify initial parameters:
A Creation Window
Touch Specify if the touch mode is enabled for the trigger. With this mode on, the trigger will react to the node by a partial contact. Otherwise, the trigger will react only if the whole bounding box will get inside of it.
Size The size of the trigger's bounding box along the X, Y and Z axes, in units.
After the initial parameters are set, click Ok and place the trigger somewhere in the world.
Editing a World Trigger
In the Trigger tab you can adjust the following parameters of the portal:
A Portal tab
Touch The size of the trigger's bounding box along the X, Y and Z axes, in units.
Bounding Box Parameters
Size Specify if the touch mode is enabled for the trigger. With this mode on, the trigger will react to the node by a partial contact. Otherwise, the trigger will react only if the whole bounding box will get inside of it.
Callbacks
A set of callbacks:
Enter The name of the enter world script callback function.
Leave The name of the leave world script callback function.
