Fundamentials
Bounds-Related Classes
Core Library
Utility Classes
Portal
A portal is a rectangular opening between two adjacent sectors, through which one sector can be partially seen if looking from another.
A Portal between Sectors
Creating a Portal
To create a portal, choose the Add World Portal option in the list of nodes of Editor panel. In the opened creation dialog window specify initial parameters:
A Creation Window
Width The width of the portal's rectangular, in units.
Height The height of the portal's rectangular, in units.
After the initial parameters are set, click Ok and place the portal somewhere in the world.
Editing a Portal
In the Portal tab you can adjust the following parameters of the portal:
A Portal tab
Bounding Box Parameters
