Fundamentials
Bounds-Related Classes
Core Library
Utility Classes
Skin Layout
General Information
All textures must be power of two in size, rectangular textures are supported, for example, 16×16, 128×32, 8×64, etc. All files are in the RGBA format.
Icons
Standard 32x32 icon
Layout
There are four states of an icon:
  1. Not pressed, not in focus.
  2. Not pressed, in focus.
  3. Pressed, not in focus.
  4. Pressed, in focus.
Assembly
Parts of the texture are copied 1:1.
Splash Screens
Texture splash screen
Layout
The texture is divided into two parts: the initial state (upper) and the final state (lower).
Assembly
While a texture splash screen is being displayed, the initial picture (upper) is gradually replaced with the final one (lower). Pseudo-animation can be created using the alpha channel: regions of the lower half with small alpha values will be shown first, regions with larger alpha values will be shown last.
Base Skin
Background texture
Assembly
The texture is resized to fit a widget.
Frame borders
Layout
Assembly
All four corners are copied 1:1 from corresponding corners of the texture:
  1. The top-left corner
  2. The top-right corner
  3. The bottom-left corner
  4. The bottom-right corner
Vertical and horizontal strips (2 pixels in width), which are located at the center of the corresponding half of the texture are used to fill in space between corners. The strips are stretched, and the resulting color bar is constructed using interpolation between colors of the pixels in the strips.
Button
Layout
The texture contains four variants of buttons in different states, the same as defined for icons. Also, each button is divided into 3 parts, which are shown below.
Assembly
All four corners are copied 1:1 from corresponding corners of the texture. Vertical and horizontal strips (2 pixels in width), which are located at the center of the corresponding half of the texture and marked as 2 and 3 on the picture are used to fill in space between corners. The strips are stretched, and the resulting color bar is constructed using interpolation between colors of the pixels in the strips.
Checkboxes and radiobuttons
Layout
The texture contains two variants of checkboxes (left column) and two variants of radio buttons (right column) for unchecked/unselected (top row) and checked/selected (bottom row) states.
Assembly
Drop-down menu
Layout
The texture contains two variants of combobox icons: closed menu (upper) and opened menu (lower).
Assembly
Background for editline and edittext widgets
Assembly
The left half of the texture is stretched to fill a widget. When pointing a mouse, it smoothly shifts to the right half.
Movable separator
Assembly
The texture is stretched to the given height.
Horizontal scroll bar
Layout
The texture is divided into five zones, each of which uses the layout similar to the icon layout. Bottom-left corner has a specific layout, since it contains unused regions (highlighted with green hatching).
Assembly
The scroll bar handle is combined from the left (1), central (3) and right (2) parts; the underlying bar is stretched to the given width.
Horizontal slider
Layout
The layout is similar to the layout of a horizontal scroll bar.
Horizontal spacer
Assembly
The texture is stretched to the given width.
Mouse pointers
Layout
There is a number of slots for different pointer states:
  1. Base pointer
  2. Operation is not permitted
  3. Drag-and-drop mode
  4. Reserved slot
  5. Changing size horizontally
  6. Changing size vertically
  7. Changing size diagonally (1)
  8. Changing size diagonally (2)
  9. Movement
  10. Rotation
  11. Scaling
Other slots are reserved.
Assembly
Selection texture
Assembly
The left half of the texture is used to highlight the text and the right one is used to highlight the selected tree element.
Spinbox
Layout
The texture is divided into two parts: the left part is for an upper arrow, the right part is for a lower arrow. The layout of each part is the same as the icon layout and contains four states:
Assembly
Tabs of the tabbox widget
Layout
Layout is the same as for buttons.
Assembly
The assembly is the same as for buttons.
Tooltip background texture
Layout
Layout is the same as for borders.
Assembly
The assembly is the same as for borders.
Texture for the treebox widget
Layout
The texture is divided into three parts:
  1. The upper left part is for folded non-leaf nodes.
  2. The lower left part is for folded non-leaf nodes.
  3. The right part is for "branches" connecting nodes.
Assembly
Movable separator
Assembly
Vertical scroll bar
Layout
Layout is similar to the layout of the horizontal scroll bar.
Assembly
Assembly is similar to the assembly of the horizontal scroll bar.
Vertical slider
Layout
Layout is similar to the layout of the horizontal slider.
Assembly
Assembly is similar to the assembly of the horizontal slider.
Vertical spacer
Assembly
Window skin
Layout
On the image below, the left half is for windows with caption and the right half is for windows without caption.
Assembly
All four corners are copied 1:1 from the corresponding corners of the texture. Vertical and horizontal strips (two pixels in width), which are located at the center of the corresponding half of the texture are used to fill in space between corners. The strips are stretched, and the resulting color bar is constructed using interpolation between colors of the pixels in the strips.
Dialogs
Base Dialog
Simple dialog
Two files are used to create a base dialog. These files correspond to two buttons of the dialog. Images are copied 1:1.
File Dialog
File selection dialog
This dialog requires four images that use the icon layout.
  • Go to the upper directory:
  • Add a tab
  • Remove the tab
  • Mini-icons for different file objects; split vertically into squares:
Image Dialog
  • Red channel toggle:
  • Green channel toggle:
  • Blue channel toggle:
  • Alpha channel toggle:
