Sandworm (Experimental)
Package Class
The Package class is a data provider for the internal FileSystem class. You can load all the resources via this class. This article describes the sample located in the <UnigineSDK>/source/csharp/samples/Api/Systems/Package/ directory.
In the C# API you can inherit from the Package class only once.
  • An example can be found in the <UnigineSDK>/source/csharp/samples/Api/Systems/Package/ directory.
  • The C++ API Unigine::Package class and the Unigine::FileSystem class which have the same methods and behavior as in the C# API.
Package Class Usage Example#
C# Side#
To use the Unigine.Package class, you should create your own class and inherit it from the Unigine.Package class and override virtual methods.
Source code (C#)
using System;
using System.IO;
using File = System.IO.File;
using System.Runtime.InteropServices;
using Unigine;
class UnigineApp {
	 * Create a class and inherit if from Unigine.Package
	class MyPackage : Package {
		private FileStream file;
		// list of files
		public override int getNumFiles() {
			Log.Warning("MyPackage.getNumFiles(): called\n");
			return 2;
		public override string getFileName(int num) {
			Log.Warning("MyPackage.getFileName({0}): called\n",num);
			if(num == 0) return "data/package.cpp";
			if(num == 1) return "data/package.world";
			return "";
		// select file
		public override int selectFile(string name,out int size) {
			Log.Warning("MyPackage.selectFile(\"{0}\",): called\n",name);
			try {
				file = null;
				if(name == "data/package.cpp") file = File.OpenRead("my_data/package.cpp");
				if(name == "data/package.world") file = File.OpenRead("my_data/package.world");
			catch(Exception e) {
				Log.Error("MyPackage.selectFile(): {0}\n",e.Message);
				size = 0;
				return 0;
			size = (int)file.Length;
		// read file
		public override int readFile(IntPtr data,int size) {
			Log.Warning("MyPackage.readFile(,{0}): called\n",size);
			try {
				byte[] src = new byte[size];
				int ret = file.Read(src,0,size);
				Marshal.Copy(src,0,data,ret);
				Log.Error("MyPackage.readFile(): {0}\n",e.Message);
				return 0;
	[STAThread]
	static void Main(string[] args) {
		// create an instance of the MyPackage class and add it to the FileSystem
		MyPackage package = new MyPackage();
		FileSystem.preloadExternPackage(package);
		// initialize engine
		Engine engine = Engine.Init(Engine.VERSION,args);
		// enter main loop
		engine.Main();
		// shutdown engine
		Engine.Shutdown();
The MyPackage class has overridden readFile(), selectFile(), getFileName() and getNumFiles() functions. The class operates with two files located in the my_data folder. In the Main() function we create an instance of the MyPackage class and add it to the FileSystem.
Unigine Script Side#
In the UnigineScript package.cpp file:
Source code (UnigineScript)
int init() {
	log.message("\n");
	log.message("Hello from My C# Package\n");
	engine.dialogMessage("Package");
Output#
The following result will be shown:
In the console:
Output
MyPackage.selectFile("data/package.cpp",): called
MyPackage.readFile(,866): called
Loading "data/package.cpp" 4ms
MyPackage.selectFile("data/package.world",): called
MyPackage.readFile(,62): called
Loading "data/package.world" 0ms
Last update: 2020-11-24
