This example shows how to:
- Create a simple car with a frame and wheels attached to it using wheel joints.
- Enable car movement using joint motors.
- Use keyboard to control car movement.
The basic workflow of creating a simple car with keyboard control is as follows:
- Create car geometry: frame and wheels.
- Assign rigid bodies and collision shapes to the frame and just a rigid body to all the wheels.
- Set up masses for the wheels and the frame.NoticeDo not use real masses (e.g. 2000 kg for the frame and 10 kg for the wheels), as joints may become unstable! It might be better to use 64 kg for the body and 25 kg for each wheel to provide realistic behavior.
- Connect the wheels to the frame using wheel joints. Set up joint parameters.
- Enable car movement using joint motors and assign movement control to corresponding keyboard keys.
The first thing we are going to address in this tutorial is the geometry of our car. We are going to create a rectangular car body and four wheels. We are also going to add some physical parameters to the geometry. So, we need two functions:
- The first one to create a box with specified parameters representing the car body:
/// function, creating a car body having a specified size, color and transformation with a body and a shape
ObjectMeshDynamicPtr createBody(char *name, const vec3& size, float mass, const vec4& color, const Mat4& transform)
// creating a car body and setting up its parameters (name, material and transformation)
ObjectMeshDynamicPtr OMD = Primitives::createBox(size);
OMD->setWorldTransform(transform);
OMD->setName(name);
// enabling collision detection for the body
OMD->setCollision(1, 0);
BodyRigidPtr body = BodyRigid::create(OMD);
body->addShape(ShapeBox::create(size), translate(vec3(0.0f)));
OMD->getBody()->getShape(0)->setMass(mass);
return OMD;
- The second one to create a cylinder with specified parameters representing a wheel:
/// function, creating a wheel having a specified size and transformation
/// with a physical body and attaching it to the frame
ObjectMeshDynamicPtr createWheel(NodePtr frame, char *name, float radius, float height, const Mat4& transform)
// creating a wheel, adding it to the frame as a child,
// and setting up its parameters (name, material and transformation)
ObjectMeshDynamicPtr OMD = Primitives::createCylinder(radius, height, 1, 32);
frame->addChild(OMD);
OMD->setTransform(transform);
OMD->setMaterialParameterFloat4("albedo_color", vec4_black, 0);
OMD->setName(name);
// enabling collision detection for the wheel
// adding a rigid body
return OMD;
Now, using these functions we can create our car. We are going to use DynamicMesh objects for the frame and four wheels. For a proper mass balance let us set frame mass equal to 64 kg and the mass of each wheel - to 25 kg.
// defining DynamicMesh objects for the frame and four wheels
ObjectMeshDynamicPtr car_frame;
ObjectMeshDynamicPtr wheels[4];
// creating car frame
car_frame = createBody("car_frame", vec3(frame_width, frame_length, frame_height), 64.0f, vec4::RED, transform);
// creating car wheels
// front left wheel
wheels[0] = createWheel(car_frame, "car_wheel_f_l", wheel_radius, wheel_width, Mat4(translate(-(frame_width + wheel_width) / 2 - delta, frame_length / 2 - wheel_radius, -frame_height / 2)* rotateY(90.0f)));
// front right wheel
wheels[1] = createWheel(car_frame, "car_wheel_f_r", wheel_radius, wheel_width, Mat4(translate((frame_width + wheel_width) / 2 + delta, frame_length / 2 - wheel_radius, -frame_height / 2)* rotateY(90.0f)));
// rear left wheel
wheels[2] = createWheel(car_frame, "car_wheel_r_l", wheel_radius, wheel_width, Mat4(translate(-(frame_width + wheel_width)/2 - delta,-0.25f * frame_length, -frame_height/2) * rotateY(90.0f)));
// rear right wheel
wheels[3] = createWheel(car_frame, "car_wheel_r_r", wheel_radius, wheel_width, Mat4(translate((frame_width + wheel_width) / 2 + delta, -0.25f * frame_length, -frame_height / 2) * rotateY(90.0f)));
Adding and Setting Up Joints#
Now that we have the frame and four wheels we can attach each wheel to the frame with a wheel joint.
To create a wheel joint we call the JointWheel() constructor and then set necessary parameters:
- Rigid body of the car frame
- Rigid body of the wheel
- Anchor point coordinates (this point is determined by the position(translation) of the wheel relative to the frame)
- Coordinates of suspension axis (a vertical axis along which a wheel moves vertically and rotates when steering)
- Coordinates of wheel spindle axis (a horizontal around which a wheel rotates when moving forward or backward)
for (int i = 0; i < 4; i++)
wheel_joints[i] = JointWheel::create(car_frame->getBodyRigid(), wheels[i]->getBodyRigid());
// calculating axes and anchor coordinates
Mat4 wheel_t = wheels[i]->getTransform();
Vec3 anchor0 = wheel_t.getTranslate();
Vec3 anchor1 = Vec3_zero;
vec3 axis00 = vec3_up;
vec3 axis10 = vec3_right;
vec3 axis11 = static_cast<vec3>(rotation(wheel_t) * axis10);
// setting up joint's anchor and axes
wheel_joints[i]->setAnchor0(anchor0);
wheel_joints[i]->setAnchor1(anchor1);
wheel_joints[i]->setAxis00(axis00);
wheel_joints[i]->setAxis10(axis10);
wheel_joints[i]->setAxis11(axis11);
// setting wheel parameters
wheel_joints[i]->setWheelRadius(wradius);
wheel_joints[i]->setWheelMass(wmass);
// setting restitution parameters
wheel_joints[i]->setLinearRestitution(0.1f);
wheel_joints[i]->setAngularRestitution(0.1f);
// setting linear damping and spring rigidity
wheel_joints[i]->setLinearDamping(400.0f);
wheel_joints[i]->setLinearSpring(100.0f);
// setting lower and upper suspension ride limits [-0.15; 0.15]
wheel_joints[i]->setLinearLimitFrom(-0.15f);
wheel_joints[i]->setLinearLimitTo(0.15f);
wheel_joints[i]->setLinearDistance(0.0f);
// setting number of iterations
wheel_joints[i]->setNumIterations(8);
Using Joint Motors#
So, we have a car, let us make it move now.
To move the car forward or backward we are going to use joint motors of the rear wheels (2 and 3):
- setting a positive velocity value will move our car forward.
- setting a negative velocity value will move our car backward.
wheel_joints[2]->setAngularVelocity(velocity);
wheel_joints[3]->setAngularVelocity(velocity);
wheel_joints[2]->setAngularTorque(torque);
wheel_joints[3]->setAngularTorque(torque);
To steer the car left or right we are going to change Axis10 coordinates of the front wheels (0 and 1) using setAxis10() method:
wheel_joints[0]->setAxis10(rotateZ(angle_0).getColumn3(0));
wheel_joints[1]->setAxis10(rotateZ(angle_1).getColumn3(0));
To stop the car we are going to set a high angular damping value for all wheels via setAngularDamping() method:
wheel_joints[i]->setAngularDamping(20000.0f);
Adding Keyboard Controls#
To add keyboard control we are going to make a handler for the keys that we need. The handler must be put to the world script update() function to be called for each frame. We are going to update car physics (joint motors) in the updatePhysics() method.
int update()
// forward and backward movement by setting joint motor's velocity and torque
if(controls->getState(Controls::STATE_FORWARD) || controls->getState(Controls::STATE_TURN_UP)) {
// TODO: increase velocity by delta
// set desired torque
} else if(controls->getState(Controls::STATE_BACKWARD) || controls->getState(Controls::STATE_TURN_DOWN)) {
// TODO: decrease velocity by delta
} else {
// TODO: decrease velocity gradually
// clamp velocity value
velocity = clamp(velocity,-90.0f,90.0f);
// steering left and right by changing Axis01 for front wheel joints
if(controls->getState(Controls::STATE_MOVE_LEFT) || controls->getState(Controls::STATE_TURN_LEFT)) {
// TODO: increase steering angle by some delta
} else if(controls->getState(Controls::STATE_MOVE_RIGHT) || controls->getState(Controls::STATE_TURN_RIGHT)) {
// TODO: decrease steering angle
} else {
// TODO: return steering angle to zero value gradually
// clamp steering angle value
angle = clamp(angle,-30.0f,30.0f);
// TODO: calculate steering angles for front joints (angle_0 and angle_1)
// set new Axis10 coordinates for front joints
if(controls->getState(Controls::STATE_USE)) {
// TODO: set a very high angular damping value for all joints
// set velocity to zero
} else {
// TODO: set angular damping value to zero for all joints
int updatePhysics()
// set angular velocity for rear joints
// set torque for rear joints
Putting it All Together#
In this section let us sum up all described above and create a new class for our car. The final code for our tutorial will be as follows:
Add a new empty car.h header file to the project, and insert the following code:
// car.h
#include "UnigineGame.h"
#include "UnigineEngine.h"
#include "UnigineObjects.h"
/// Car class definition
class Car
// car parameters
float frame_width;
float frame_height;
float frame_length;
float wheel_radius;
float wheel_width;
// initialization of movement parameters
float angle = 0.0f;
float velocity = 0.0f;
float torque = 0.0f;
Car() { }
~Car() { }
int update();
int init(float blength, float bwidth, float bheight, float wradius, float wwidth, float wmass, const Unigine::Math::Mat4& transform);
int updatePhysics();
// car elements
Unigine::ObjectMeshDynamicPtr car_frame;
Unigine::ObjectMeshDynamicPtr wheels[4];
Unigine::JointWheelPtr wheel_joints[4];
Unigine::ControlsPtr controls;
Add a new empty car.cpp file to the project, and insert the following code:
// car.cpp
#include "car.h"
/// function setting up bodies for a wheel joint
void setBodies(JointWheelPtr joint, const BodyRigidPtr &car_body, const BodyRigidPtr &wheel_body)
joint->setBody0(car_body);
joint->setBody1(wheel_body);
Mat4 wheel_t = wheel_body->getObject()->getTransform();
joint->setAnchor0(anchor0);
joint->setAnchor1(anchor1);
joint->setAxis00(axis00);
joint->setAxis10(axis10);
joint->setAxis11(axis11);
OMD->setName(name);
// enabling collision detection for the frame
return OMD;
OMD->setName(name);
return OMD;
/// Initializing a car with specified frame and wheel parameters
int Car::init(float blength, float bwidth, float bheight, float wradius, float wwidth, float wmass, const Mat4& transform)
frame_width = bwidth;
frame_height = bheight;
frame_length = blength;
wheel_radius = wradius;
wheel_width = wwidth;
float delta = 0.2f;
// initialization of wheels
// initialization of wheel joints
wheel_joints[i] = JointWheel::create();
// setting bodies and wheel parameters
setBodies(wheel_joints[i], car_frame->getBodyRigid(), wheels[i]->getBodyRigid());
// setting up player and controls
PlayerPersecutorPtr player = PlayerPersecutor::create();
player->setFixed(1);
player->setTarget(car_frame);
player->setMinDistance(6.0f);
player->setMaxDistance(11.0f);
player->setPosition(Vec3(0.0f, -10.0f, 6.0f));
player->setControlled(0);
Game::setPlayer(player);
Game::setEnabled(1);
/// method updating current car state with a keyboard control handler
int Car::update()
float ifps = Game::getIFps();
velocity = max(velocity, 0.0f);
velocity += ifps * 50.0f;
torque = 5.0f;
else if (controls->getState(Controls::STATE_BACKWARD) || controls->getState(Controls::STATE_TURN_DOWN))
velocity = min(velocity, 0.0f);
velocity -= ifps * 50.0f;
torque = 5.0f;
else
velocity *= Math::exp(-ifps);
velocity = clamp(velocity, -90.0f, 90.0f);
angle += ifps * 100.0f;
else if (controls->getState(Controls::STATE_MOVE_RIGHT) || controls->getState(Controls::STATE_TURN_RIGHT))
angle -= ifps * 100.0f;
else
if (Math::abs(angle) < 0.25f) angle = 0.0f;
else angle -= sign(angle) * ifps * 45.0f;
angle = clamp(angle, -30.0f, 30.0f);
// calculating steering angles for front joints (angle_0 and angle_1)
float base = 3.3f;
float width = 3.0f;
float angle_0 = angle;
float angle_1 = angle;
if (Math::abs(angle) > Consts::EPS)
float radius = base / Math::tan(angle * Consts::DEG2RAD);
angle_0 = Math::atan(base / (radius + width / 2.0f)) * Consts::RAD2DEG;
angle_1 = Math::atan(base / (radius - width / 2.0f)) * Consts::RAD2DEG;
// enabling or disabling a brake
if (controls->getState(Controls::STATE_USE))
velocity = 0.0f;
else
wheel_joints[i]->setAngularDamping(0.0f);
/// method updating car physics
int Car::updatePhysics()
In the AppWorldLogic.h file, define our car.
// AppWorldLogic.h
#include "car.h"
Car car;
// AppWorldLogic.cpp
int AppWorldLogic::init() {
Physics::setGravity(vec3(0.0f, 0.0f, -9.8f * 2.0f));
Physics::setFrozenLinearVelocity(0.1f);
Physics::setFrozenAngularVelocity(0.1f);
//enabling collision for the ground
NodePtr ground = World::getNodeByName("ground");
if (ground)
checked_ptr_cast<Object>(ground)->setCollision(1, 0);
checked_ptr_cast<Object>(ground)->setPhysicsIntersection(1, 0);
// initializing our car
car.init(4.0f, 2.0f, 0.5f, 0.5f, 0.5f, 25.0f, translate(Vec3(0.0f, 0.0f, 2.1f)));
int AppWorldLogic::update() {
//updating our car
car.update();
int AppWorldLogic::updatePhysics() {
// updating car physics
car.updatePhysics();
