Customizing Mouse
Customizing Mouse
This example shows how to customize mouse cursor appearance and change default mouse behavior in your application. It will help you to solve the following tasks:
  • Changing the default mouse cursor image
  • Toggling mouse cursor's visibility
  • Restricting mouse cursor movement to application window's area
Using Defines to Control Mouse Behavior#
The mouse is handled by the system script and there are three modes available:
  • Default - the mouse is grabbed when clicked (the cursor disappears and camera movement is controlled by the mouse).
  • MOUSE_SOFT (enabled by the corresponding define) - the mouse cursor disappears after being idle for a short time period.
  • MOUSE_USER (enabled by the corresponding define) - the mouse is not handled by the system (allows input handling by some custom module).
Basically there are two ways you can use these defines:
  • Add the following line
    Source code (UnigineScript)
    #define MOUSE_SOFT
    (or the same for MOUSE_USER) to your system script file (unigine.usc)
  • Add an extern_define startup command-line option. You can either set in UNIGINE SDK Browser or manually via the command line:
    Shell commands
    your_app_name* -extern_define MOUSE_SOFT
    (or the same for MOUSE_USER).
Customizing Mouse Cursor#
You can change the look of the mouse cursor in your application using any square RGBA8 image you want. This can be done by simply adding the following lines to your code (e.g. world's init() method):
ImagePtr mouse_cursor = Image::create("textures/cursor.png");
mouse_cursor->resize(mouse_cursor->getWidth(), mouse_cursor->getWidth());
if (mouse_cursor->isLoaded() && mouse_cursor->getFormat() == Image::FORMAT_RGBA8)
	App::setMouseCursor(mouse_cursor->getPixels(), mouse_cursor->getWidth());
	App::setMouseShow(1);
// clearing pointer
mouse_cursor.clear();
Sample cursor image
Example Code#
  • Sets a custom icon and title for the application window
  • Sets a custom mouse cursor
  • Switches between the following two mouse control modes by the ENTER key:
    • Camera control - the cursor is invisible and controls the camera (movement area restricted to the application window)
    • UI control - the cursor is visible and can be used to interact with application UI (movement area unrestricted)
  • Switches between restricted (only application window area) and unrestricted mouse movement mode by the SHIFT key
// AppWorldLogic.cpp
#include "UnigineApp.h"
#include "UnigineUserInterface.h"
#include "UnigineGui.h"
#include "UnigineGame.h"
// auxiliary variables
ControlsPtr controls;
GuiPtr gui;
// widgets
WidgetLabelPtr label;
WidgetButtonPtr button;
/// function toggling the mouse cursor's state
void ToggleMouseCursor()
	// getting current mouse state
	int enabled = ControlsApp::isMouseEnabled();
	// toggling movement restriction to the application window area
	App::setMouseGrab(1 - enabled);
	// toggling mouse interaction with GUI elements
	gui->setMouseEnabled(enabled);
	// toggling mouse control
	ControlsApp::setMouseEnabled(1 - enabled);
int AppWorldLogic::init()
	gui = Gui::get();
	// seting a custom icon for the application window
	ImagePtr icon = Image::create("textures/cursor.png");
	if (icon->isLoaded() && icon->getFormat() == Image::FORMAT_RGBA8)
		App::setIcon(icon->getPixels2D(), icon->getWidth());
	icon.clear();
	// seting a custom title for the application window
	App::setTitle("Custom Window Title");
	// preparing UI: creating a label and a button and adding them to the GUI
	label = WidgetLabel::create(gui);
	button = WidgetButton::create(gui, "BUTTON");
	button->setPosition(10, 40);
	gui->addChild(label, Gui::ALIGN_OVERLAP | Gui::ALIGN_TOP | Gui::ALIGN_LEFT);
	gui->addChild(button, Gui::ALIGN_OVERLAP | Gui::ALIGN_TOP | Gui::ALIGN_LEFT);
	// clearing pointer
int AppWorldLogic::update()
	// checking for STATE_USE (ENTER key by default) and toggling mouse cursor state "hidden restricted camera control" <-> "visible unrestricted UI control"
	if (controls->clearState(Controls::STATE_USE) == 1)
		ToggleMouseCursor();
	// checking for STATE_RUN (SHIFT key by default) and toggling mouse cursor movement restriction to application window bounds
	if (controls->clearState(Controls::STATE_RUN) == 1)
		App::setMouseGrab(!App::getMouseGrab());
	// updating cursor position info
	label->setText(String::format("\n MOUSE COORDS: %d, %d)", App::getMouseX(), App::getMouseY()));
	// showing or hiding mouse cursor depending on its current state
	App::setMouseShow(!ControlsApp::isMouseEnabled());
int AppWorldLogic::shutdown()
	//removing all widgets grom GUI
	for (int i = 0; i < gui->getNumChildren(); i++)
		gui->removeChild(gui->getChild(i));
	// clearing pointers
	controls.clear();
	button.clear();
	label.clear();
	gui.clear();
Let us also use the following option to enable user mouse handling: -extern_define MOUSE_USER
Last update: 2019-12-25
