The Language
Core Library
Engine Library
Plugins Library
C++ API
Integration Samples
C++ Plugins
Unigine Material Library
Switcher
A switcher is a cuboid shaped object, switching off (or turning on) all of the nodes inside of it immediately.
A world switcher should be a parent node for the nodes it controls.
Creating a Switcher
To create a world switcher, choose the Add World Switcher option in the list of nodes in Editor panel. In the creation dialog window, specify initial parameters:
A Creation Window
Point A flag, indicating if the distance to the object is counted from the bounding box center (if disabled, the distance will be counted from its nearest edge).
Size The size of the switcher's bounding box along the X, Y and Z axes, in units.
After the initial parameters are set, click Ok and place the world switcher somewhere in the world.
Editing a Switcher
In the Switcher tab you can adjust the following parameters of the switcher:
A Switcher tab
Bounding Box Parameters
Point A flag, indicating if the distance to the object is counted from the center of the bounding box (if disabled, the distance will be counted from its nearest edge).
Offset The offset of the switcher's bounding box along the X, Y and Z axes, in units.
Switching Off Parameters
Switching of distances:
Min distance The minimum distance of visibility, in units. If a camera is closer to a node than this minimum distance, a node is not visible.
Max distance The maximum distance of visibility, in units. If a camera is further from a node than this maximum distance, a node is not visible.
